my denon avr can't seem to handle 1080p 3d properly - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-26-2011, 05:15 PM - Thread Starter
TheGuyInTheChair's Avatar
I've noticed that regularly if I try watch 3d content it messes up
I get sparkles all over the screen. I will have the audio and video cut out. Or it will nit display anything. Also it will for some reason only show dts on a dts hd track
I've tried 3 different players and probably 5 different hdmi 1.4 cables
if I take the avr out of the equation it seems to work fine
anyone have any idea on how I could fix this?
the model is avr-391
TheGuyInTheChair is offline
post #2 of 5 Old 08-27-2011, 08:22 AM
Don Landis's Avatar
Quoted: 1222 Post(s)
Liked: 327
Suggest you contact denon. Is the avr391 specification ok for 3D hdmi? My avr4311ci is and it works great for 3D. Sparkles usually means bad hdmi connection. Try other hdmi ports to see if the problem is local to a possible bad port on the avr.
My 3D videos and more
Don Landis HT System: Projector Sony VPL VW665ES Players: Samsung UBD K8500 OPPO BD93 Sony BDP S6200 All Regions Player Denon AVR 4311ci, 7.1 JBL Professional series and Klipsch PS3, XBOX360, Dish VIP722K
Don Landis is offline
post #3 of 5 Old 08-27-2011, 11:28 AM - Thread Starter
I've tried all 4 ports on my TV and none of them are good
The problem is I have no warranty coverage on my AVR since I bought it in the US and live in Canada so I'd have to take it to the states to have it fixed
I was hoping there was maybe something I could do myself
post #4 of 5 Old 08-27-2011, 01:29 PM
Don Landis's Avatar
Liked: 327
I wanted you to try other ports on the AVR. I thought you did connect the 3D source to the TV direct and it was OK.
post #5 of 5 Old 09-10-2011, 01:04 AM
Rob Britton's Avatar
I had the same problems with panasonic 350 blu-ray player going into NAD 785hd with the new 150vm card. Into a panasonic 65vt25 and I changed settings in the Blu-ray player from 4:4:4 to 4:2:2 and everything is great now.
Rob Britton is offline
Reply 3D Source Components
