Panasonic DMP-BDT110 2D/3D Conversion Issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-18-2011, 01:50 PM - Thread Starter
deadman64's Avatar
Can someone help me out? I just purchased the 110 and I can't get the 2d->3d conversion to work (or it could be all 3d, as I dont own any 3d bluray movies).
Anyways, I tried converting a DVD and a bluray using the conversion and the screen goes to black, the player displays HDMI and then the counter comes back on the player like the movie is playing, but my TV displays "No Signal" and is obviously black. No audio is heard.
At first I had an hdmi 1.3 so i got this cable off amazon: "BlueRigger High Speed HDMI Cable with Ethernet 6.6 Feet (2m) - Supports 3D and Audio Return [Latest Version]"
I tried to convert a bluray movie again using my new cable and the exact same thing as above happens. My TV is a VIZIO XVT3D474SV. And I have tried 3D with on demand and ESPN 3d and they both work on the TV, so my TV's 3D is working.
What am I doing wrong? I called technical support and he had me go buy an SD card to put into the player (not sure why that would be needed for a conversion...) but I got a cheap card and formatted it on the player but it changed nothing.
Someone mentioned to me there was an issue between Panasonic and Vizio TVs
Thanks for reading
deadman64 is offline
post #2 of 3 Old 09-19-2011, 09:54 AM
Rudy1's Avatar
Quoted: 964 Post(s)
Liked: 1276
Take a look at this thread...it may offer some insight on how to get things working:
http://www.avsforum.com/avs-vb/showthread.php?t=1350349
ASKHOLE: (n.) A person who constantly asks for your advice, yet always does the opposite of what you told them.
Rudy1 is online now
post #3 of 3 Old 09-19-2011, 10:32 AM
JOHNnDENVER's Avatar
Pretty sure before hand, you need to switch the 3D in the display to SBS?
JOHNnDENVER is offline
Reply 3D Source Components
Panasonic Dmp Bdt110 3d 2d Blu Ray Disc Player , Panasonic 3d Blu Ray Disc Player Dmp Bdt110
