Vegas Render Error - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-18-2011, 03:30 PM - Thread Starter
bravia3D's Avatar
Liked: 33
Trying to render my new movie but keep getting an error once Vegas tries to created the image file. A red X pops up and it says "An error occurred creating the image." Under details it says, Status: Found two different objects associated with the same URI
What does this mean? And is there a way to fix it? First time this has happened. I have plenty of disc space.
I have a feeling it means I used the same video file on the timeline twice?
3D items I own:
Sony 46" LX900 active 3D set
Sony HMZ-T3 (Cushion pads and light blocker mod)
LG LW6500 passive 3D set
PS3 & PS4
Sony BDP-S570 BD3D player
JVC-GS-TD1 (with Cyclopital base extender)
Fujifilm W3
Sony Alpha 55 (for 3D panoramic photos)
Quadcopter + Zenmuse and GoPro Hero 3 (Filming...
bravia3D is offline
post #2 of 9 Old 09-19-2011, 12:00 AM
Don Landis's Avatar
Quoted: 1222 Post(s)
Liked: 326
It appears you may have something corrupted on your hard drive as the error indicates it is trying to access the same file identifier stored in two different locations. I've never seen this but you may want to do a hard drive cleanup using the appropriate tools for your OS.
My 3D videos and more
Don Landis HT System: Projector Sony VPL VW665ES Players: Samsung UBD K8500 OPPO BD93 Sony BDP S6200 All Regions Player Denon AVR 4311ci, 7.1 JBL Professional series and Klipsch PS3, XBOX360, Dish VIP722K
Don Landis is offline
post #3 of 9 Old 09-19-2011, 05:38 AM - Thread Starter
bravia3D's Avatar
Liked: 33
Nope, that wasn't it. I used a scene twice on the same timeline, the scene had the same name and Vegas seemed not to like that. Once I changed the scene or renamed it, it worked just fine!
But as always Don, thanks for your help!
3D items I own:
PS3 & PS4
Fujifilm W3
bravia3D is offline
post #4 of 9 Old 09-19-2011, 11:32 AM
Don Landis's Avatar
Liked: 326
I do this all the time and has never caused that error. Why would Vegas not like it on your project and not care on mine? I think this goes deeper than you believe and got fixed with your method but not for reasons you believe. If it never happens again then who cares? but let's not think Vegas has this limitation because it doesn't.
post #5 of 9 Old 09-19-2011, 01:16 PM
markr041's Avatar
Quoted: 764 Post(s)
Liked: 240
Don is correct (of course). I hate to admit it but I have accidentally included the same clips twice (or more) in a timeline and Vegas happily rendered the video, unfortunately.
Heaven forbid, though, software that decides what I should have on my timeline!
markr041 is offline
post #6 of 9 Old 09-19-2011, 03:39 PM - Thread Starter
bravia3D's Avatar
Liked: 33
That is weird, I know nothing is wrong with my PC or HD. I tried adding another same file with the same result error. Once I renamed it, bingo worked fine.
3D items I own:
PS3 & PS4
Fujifilm W3
bravia3D is offline
post #7 of 9 Old 09-19-2011, 04:06 PM
Don Landis's Avatar
Liked: 326
Are you in denial?
Just teasing. Best to run some diagnostics. maybe you also need to do a fresh reinstall. Sorry, but that is how I usually fix stuff here when I can't put my finger on it.
Also, have you done a Google search on your error message? I just did and it appears many have had similar errors when something wasn't quite right and those reports were with other applications. One source indicated corrective action was achieved with reinstalling Net Framework. The bad news is your minor, fixable, problem now may be a preview of worse failures. Also you can contact Sony and they may offer you a resolution you can try.
post #8 of 9 Old 09-20-2011, 05:34 AM
bigbarney's Avatar
Quoted: 163 Post(s)
Liked: 60
You can use the same scene on the time line as many times as you wish....1.... 10... 100 times. It should (and does) make no difference at all.
bigbarney is offline
post #9 of 9 Old 09-20-2011, 03:24 PM - Thread Starter
bravia3D's Avatar
Liked: 33
Well, just to be safe I reformatted and did a fresh reinstall. So far no errors
3D items I own:
PS3 & PS4
Fujifilm W3
bravia3D is offline
Reply 3D Source Components
