Update: Need help deciding hardware Post #4 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-22-2011, 08:27 AM - Thread Starter
kgonepostl's Avatar
I have a mitsubishi 3d ready tv and am about to throw down for some glasses and the adapter needed but I need to know of a program that can mount my backed up iso files.
I have a computer running an hdmi cable to the back of my mitsubishi tv. All my backed up iso's are ready to be mounted I just don't know what to use to ensure my back ups will display 3d properly
kgonepostl is offline
post #2 of 6 Old 09-22-2011, 08:49 AM
Z0p
Z0p's Avatar
I use this one and it works well for me:
http://www.slysoft.com/en/virtual-clonedrive.html
I use TMT5 to play the files.
Z0p is offline
post #3 of 6 Old 09-22-2011, 04:59 PM - Thread Starter
kgonepostl's Avatar
***question answered.
post #4 of 6 Old 09-22-2011, 05:42 PM - Thread Starter
kgonepostl's Avatar
This whole 3d thing is really confusing. I'm buying the adapter for my mitsubishi Here for my Mitsubishi WD-60C10 and dlp link glasses from Here I'll be using this software to play my mounted iso's TMT5
If somebody could check my links that knows a lot about 3d. Let me know if I'm on the right track PLEASE let me know. I don't have a lot of money and want to make this work the first time.
Also, does it matter what kind of video card I have?
post #5 of 6 Old 09-23-2011, 08:43 AM
Z0p
Z0p's Avatar
If you are using TMT5 you can see the tech requirements here, including video card and display requirements. They may not have listed your display yet if it is a newer TV. You may want to ask them about it or ask in the Display or 3d Display sections of AVS.
http://www.arcsoft.com/totalmedia-theatre/techspec.html
Z0p is offline
post #6 of 6 Old 09-23-2011, 12:40 PM - Thread Starter
kgonepostl's Avatar
Ok so since I have a radeon hd5350 I need a new video card, the adapter for my tv and at least one pair of dlp-link shutter glasses. My oh my is this getting expensive.
Reply 3D Source Components
