Cisco RNG200 DVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-22-2011, 11:35 AM - Thread Starter
DougReim's Avatar
Liked: 24
Hello,
I've got Comcast's Cisco branded RNG200 cable box and my TV (Mitsubishi WD73738) will not play top & bottom 3D in 1080. I have to change the signal to 720 which I've done on my DVD players but I can't find any instructions on how to do that with my cable box. Does anybody know how to change the cable box's output to 720p?
Thanx
Doug
TV Room Upgrade Completed
DougReim is offline
post #2 of 3 Old 09-26-2011, 12:29 PM
Ken H's Avatar
• Make sure the set-top is Off and the TV is On.
• On the front panel of the set-top, press GUIDE and INFO at the same time.
• Follow the on-screen instructions to choose HD or SD mode and wide screen (16:9) or standard
screen (4:3) depending upon your TV type.
• At the conclusion of the on-screen instructions, press POWER on the set-top to begin watching TV.
User Manual:
http://media2.comcast.net/anon.comca..._userguide.pdf
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #3 of 3 Old 09-27-2011, 12:50 PM - Thread Starter
DougReim's Avatar
Liked: 24
Thanks Ken H...got it and I'm sure that manual will come in handy down the road. As far as down converting to 720p I found it's easier to change the setting on my AVR.
Doug
DougReim is offline
Reply 3D Source Components
