question about hdmi - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-26-2011, 10:31 AM - Thread Starter
readyfor3d's Avatar
i have an insignia 10.2 gps high speed hdmi cable, but am thinking about getting the monster 1000 hdmi. Will that cable really make much of a difference in my 3d experience before i spend the extra money? thanks!
readyfor3d is offline
post #2 of 5 Old 09-26-2011, 12:37 PM
Ken H's Avatar
No.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #3 of 5 Old 09-26-2011, 12:46 PM
E-JTL's Avatar
Originally Posted by Ken H View Post
No.
Actually, Ken, you're wrong. What you SHOULD have typed is, "NO!"
See, you forgot the all caps and the exclamation point.
E-JTL is offline
post #4 of 5 Old 09-26-2011, 12:55 PM - Thread Starter
readyfor3d's Avatar
so u wouldnt buy the 17 gbps monster?
post #5 of 5 Old 09-26-2011, 01:24 PM
E-JTL's Avatar
I wouldn't buy ANYTHING Monster. They are way way overpriced.
Just go to Monoprice.com and get some HDMI cables from there.
There you go. I have these for every component I use and they work perfectly. PS3, Xbox 360, Onkyo Receiver, Apple TV, Dish Network box... I have an LG 3d tv...no issues at all.
E-JTL is offline
Reply 3D Source Components
