3DTV not detecting 3D signal from PC - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 35 Old 07-04-2013, 09:48 AM
Dr. Righteous's Avatar
And UPDATE:::::
I spoke to Vizio support again; this time they owned up to the problem as a KNOWN ISSUE on their part.
He said the new firmware will be going out soon.
So looks like the fix is in the pipeline.
This is great; not been able to play any 3D games for 2 months.
Dr. Righteous is offline
post #32 of 35 Old 07-06-2013, 10:00 AM
Ziggy49's Avatar
New update ran last night, working fine now
Originally Posted by Dr. Righteous View Post
And UPDATE:::::
Ziggy49 is offline
post #33 of 35 Old 07-06-2013, 05:54 PM
Yes.
I was pleasantly surprised when I turned on my Vizio TV and had a message that new firmware was applied. When I checked 3D it worked fine on the games I tried.
Firmware version for my E3D320VX is 3.18.3.1175.
post #34 of 35 Old 10-16-2013, 03:16 AM
skank's Avatar
Im experienceing exact same issue with sony hw30 beamer
It gets no 3d signal
resolution set to 1080p 24hz
but still no signal
supra 1.4 hdmi cable
skank is offline
post #35 of 35 Old 10-26-2013, 12:01 AM
tdk666's Avatar
Vizio M55 series with a dell zeno htpc. Unsure of firmware.
3d mode was not an option on the tv. Input display on the tv was showing 1920x1080. I checked the computer display output and it was pushing 60hz. Dropped that down to 24hz and the tv showed new input resolution of 1080p. 3d was then enabled.
I think the issue is that the Vizio only can display 3d at a sub 30hz rate, so your computer needs to let the tv know its pushing out something in that range. Any driver issues might just be related to the scaling down off the default computer refresh rate, which will be 60hz. (Or something)
tdk666 is offline
Reply 3D Source Components
