1.4 HDMI required for 3d? Need 1.4 splitter for multiple 3d devices? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-13-2012, 11:45 AM - Thread Starter
stevedawg85's Avatar
Quoted: 23 Post(s)
So I am wiring my theatre room and only want to do this once in 10 years, major headache! I plan on purchasing a 3d projector and will use my ps3, computer, (and next gen of consoles?) for 3d gaming and videos.
I already have a 1.3 hdmi cable, do I need to buy a 1.4 hdmi cable to run from projector to wall. then into the wall will be a splitter, again, do I need a specific 1.4 splitter for my 3d devices?:
Projector----HDMI----Wall Plate----SPLITTER---(computer, ps3, xbox720, cable box, etc.)
stevedawg85 is offline
post #2 of 4 Old 05-23-2012, 09:28 AM - Thread Starter
Quoted: 23 Post(s)
bump:
Do I need a specific 1.4 splitter for my 3d devices?
post #3 of 4 Old 05-23-2012, 10:28 AM
GEP
GEP's Avatar
Originally Posted by stevedawg85 View Post
bump:
1. There is no such thing as a HDMI 1.4 cable there is only:
Standard Speed cable
Standard Speed cables that support eithernet
High Speed cables
High Speed cables that support eithernet
Automotive HDMI cable.
For longer distance and if using a source/sources capable of 1920 x 1080p 60Hz or higher it is best to use High Speed cables.
The next part of your question is somewhat reversed.
2. You do not want a "splitter" you want a "switch".
Slimpified:
A "splitter" will take one source device, such as your Blu-ray player, and send that signal to mulitple display (sync) devices, such as a TV and a projector or mulitple TVs.
A "switch" will connect multiple source devices such as your, computer, PS3, X-box, satellite reciever or cable box, to one display device. You then select which device to watch on the switch (some are automatic).
3. Yes your switch needs to indicate in the specs that it supports 3D pass-thru. Do not look for just 1.4 because 1.4 does not require 3D support, 3D support is optional. As a matter of fact do not worry about 1.3 or 1.4 in your switch look specifically at the specs for the switch and look for support of 3D pass-thru.
GEP is offline
post #4 of 4 Old 05-23-2012, 11:08 AM - Thread Starter
Quoted: 23 Post(s)
awesome! thanks for the info gep
Reply 3D Source Components
