Question about 3D PS3 games - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-28-2012, 05:21 AM - Thread Starter
danc8379's Avatar
I have a new Samsung D550 plasma and have no problem watching 3d content either on D* or on Blu Ray 3d through the PS3. However, I have 2 games that are 3d compatible (Arkham City and Sonic Generations) and I can't figure out how to get them to display in 3d. I don't get an option to play in 3d, and it doesn't come on automatically in 3d mode. Does anyone have any suggestions? Thanks.
danc8379 is offline
post #2 of 7 Old 03-29-2012, 05:00 AM
joeshan99's Avatar
I know sonic has a option under the "press start" on the main menu.
joeshan99 is offline
post #3 of 7 Old 03-29-2012, 05:30 AM
TonyDP's Avatar
Quoted: 307 Post(s)
Liked: 203
Both games have options for turning on 3D in their menus. Go there and you should be all set.
Xbox Live: XboxPhantom
PSN: TonyDP
TonyDP is offline
post #4 of 7 Old 03-29-2012, 05:53 PM - Thread Starter
danc8379's Avatar
Something isn't working then because I don't have that option on either game. Not sure what I could do differently.
danc8379 is offline
post #5 of 7 Old 03-30-2012, 06:49 AM
Rudy1's Avatar
Quoted: 991 Post(s)
Liked: 1350
Have you tried going through the initial 3D display setup procedure for the PS3 again? I had the same issues with a 3D game, then someone on the PSN forum suggested I try that so I did and it worked.
ASKHOLE: (n.) A person who constantly asks for your advice, yet always does the opposite of what you told them.
Rudy1 is online now
post #6 of 7 Old 03-30-2012, 01:03 PM - Thread Starter
danc8379's Avatar
Yes...did that a couple of times. And all other 3d is working, including movies on the PS3.
danc8379 is offline
post #7 of 7 Old 04-04-2012, 07:34 PM
Boomzzilla's Avatar
Thats weird I have a Samsung D550 plasma and have not tried the games you listed but have played Killzone 3,GT5 and uncharted 3 in 3D no problems.Do you have a decent quality 1.4 HDMI cable?Also 3D only worked on TV via direct input and not through a receiver.
Boomzzilla is offline
Reply 3D Source Components
