Help with Samsung BD-D6700 and HDMI 1.3 receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-05-2012, 08:41 AM - Thread Starter
overdrive79's Avatar
I just received my Samsung pn64d8000 and since I don't have a 3d ready receiver, I went to best buy and decided to get the Samsung BD-D6700 for the dual hdmi output.
After messing around for hours, I finally got audio to work over HDMI to the reciever while seeing a 2D Image on the TV at the same time, but once I enable 2D-3D (I don't have any 3D Blurays yet), the sound drops out no matter how I have it hooked up.
The only thing I noticed that might be contributing is the "AnyNet" feature, or whichever feature that the TV uses to know whether I turning the reciever volume up and down.
I may try turning that off. Any other suggestions?
overdrive79 is offline
post #2 of 6 Old 04-05-2012, 11:29 AM - Thread Starter
I turned off anynet, but that did not change anything.
post #3 of 6 Old 04-05-2012, 12:10 PM
RonAlam's Avatar
Quoted: 12 Post(s)
Liked: 30
is the bly ray player setup to output only audio from the second HDMI output? I know the panasonics asks you how you want the second HDMI to work.
RonAlam is offline
post #4 of 6 Old 04-05-2012, 12:56 PM - Thread Starter
The options are Dual HDMI and Auto. I have it set to auto.
post #5 of 6 Old 04-06-2012, 12:58 PM - Thread Starter
I forgot to turn off anynet on the BD player as well. It seems the anynet would tell the receiver to switch to "TV/SAT" which doesn't even have an HDMI assigned to it.
post #6 of 6 Old 05-28-2012, 07:57 AM
qbbraveheart's Avatar
A little OT, but where did you get yours from? I have been trying to find one but have had no luck.
qbbraveheart is offline
Reply 3D Source Components
Samsung 3d Blu Ray Disc Player Bd D6700 , Samsung Bd D6700 3d Blu Ray Disc Player
