Playing 3D Blu-ray thru PC with Dual Projectors - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-02-2012, 01:25 PM - Thread Starter
ojuicy's Avatar
So I have purchased the Omega 3D Kit and am currently trying to setup my dual projectors to play 3D movies. I have ripped a 3D Blu-ray using DVDFab into a MKV format. I am then trying to play that file using the Stereoscopic Player with the playback settings set to Dual Screen Output, however when I do there is nothing displayed on either screen. Does anyone know where I went wrong? Should I be ripping the Blu-ray with a different format (mpeg4?)? Or should I be using a different setting for viewing output in Stereoscopic Player? Thank you so much for your time/help.
ojuicy is offline
Reply 3D Source Components
