Can PS3 directly play MTS files from Sony TD10 in 3D? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-19-2012, 11:52 AM - Thread Starter
kuebler's Avatar
Quoted: 14 Post(s)
As a video layman I have searched, but not found a solution for my problem. Sorry if something similar has been answered before.
I have some 500 *.mts video files, recorded in FullHD 3D MVC with a Sony TD10 camcorder (PAL).
Unfortunately I can get them to play via my PS3 only in 2D. This is regardless to whether I give these files directly to my PS3 with an USB stick, or whether I stream them from my Mac using a server (PMS). In both cases they play fine on my LG 3D TV attached to the PS3, but only in 2D.
I know that I can burn 3D Bluray discs from MTS files, but with my 500 files this is not a really feasible solution.
Is there any possibility to solve my problem? Thanks for any support.
Falk Kuebler
kuebler is offline
post #2 of 8 Old 05-20-2012, 01:53 AM - Thread Starter
kuebler's Avatar
Quoted: 14 Post(s)
No pitying soul?
Falk Kuebler
kuebler is offline
post #3 of 8 Old 05-20-2012, 08:46 AM
chang69's Avatar
On my pc I use PlayMemories. It plays the MTS default in 3D. Can you try PlayMemories on the PS3? It would answer a question I have.
chang69 is offline
post #4 of 8 Old 05-20-2012, 09:11 AM - Thread Starter
kuebler's Avatar
Quoted: 14 Post(s)
As I understood it, PlayMemories is an online service. You upload your video files with Sony support, and then PlayMemories cares for the eventual downstreaming, converting them on-the-fly to whatever format your local device requires.
Unfortunately this does not solve my problem: I want to keep my videos in 3D FullHD. With the TD10's MVC coding this is at a bit rate of 26 MBit/sec, which is not feasible for my network. Furthermore I want to keep my files local, e.g. for when I edit them, use non-Sony *mts files, or whatever.
So until someone tells me a way to feed my PS3 with an mts file (without first embedding it into a Bluray structure or into an an AVCHD structure), I see my chances dim with every hour progressing without a hint...
Falk Kuebler
kuebler is offline
post #5 of 8 Old 05-20-2012, 11:23 AM
chang69's Avatar
I understood that PlayMemories PS3 also plays content from it local harddrive.
chang69 is offline
post #6 of 8 Old 05-20-2012, 12:50 PM - Thread Starter
kuebler's Avatar
Quoted: 14 Post(s)
I just installed PlayMemories PS3. Unfortunately when using a menu point to copy "images" (there is no alternative) from the USB stick to the PS3-internal disk, then I get sort of an "image access error" message (in German)
Falk Kuebler
kuebler is offline
post #7 of 8 Old 05-21-2012, 04:30 AM
chang69's Avatar
That's too bad. :-( Strange that Playmemories on PC does recognize 3D MTS.
chang69 is offline
post #8 of 8 Old 05-23-2012, 08:52 AM
bsprague's Avatar
Quoted: 494 Post(s)
Liked: 180
Can't help with the PS3. Instead, I play 3D*.mts files from a Panasonic SDT-750 on a WD Live Streaming Video Player. My Sony TV has to be manually switched to 3D or I see the side-by-side.
bsprague is online now
Reply 3D Source Components
