I'm buying next week Mitsubishi 82" DLP 3D? Just need opinion about 2011's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-11-2012, 07:17 PM - Thread Starter
Lindy1's Avatar
teh NEW 2012 82", 92" adn UP will be for saLE THE END OF THIS MONTH. sO- WHATS THE MAIN DIFFFERENCE IN THE 2011 82' AND THE 1012 82"? (sorry bout the accidental capitals) the only diference I can tell is the sound system. Please give your input on this... thanks!!
Lindy1 is offline
post #2 of 3 Old 06-12-2012, 11:01 AM
GEP
GEP's Avatar
To get the details go to www.mitsubishi-tv.com.
The 2011 models have model numbers that end in the following last three digits.
C11 - entery model (good)
640 - basic model (good)
740 - step up model (better)
840 - Diamond Series model (best)
The 2012 models have model number that end in the following last three digits.
C12 - entery model - not 3D (good)
642 - basic 3D model (good)
742 - step up model (better)
842 - Diamond Sereis model (best)
As for the sound system - that is a difference or step up between the 740/742 series and the 840/842 series. Not a difference between 2011 and 2012.
All have good to exellent pictures - the step ups mostly deal with other feature upgrades. Some of these feature upgrades may be important to some and not others. Such as the higher end audio or additional color controls of the 840/842 series or the internet features of the 740/742 and 840/842 series. Sometimes you need to purchase some extra features you do not want in order to get the extra features you do want - however this is the way of life in almost everything.
GEP is offline
post #3 of 3 Old 06-13-2012, 12:05 PM
walford's Avatar
Normally the top model for each manufacturer uses a newer and faster video processing chip and have an inproved upscaling chip which has a better upscaling algorithim. The newest chips also have minor PQ improvements which may have more buffers. These improvements are not contained in the specs and are normally only discussed by technically compentent reviewers.
walford is offline
Reply 3D Source Components
