Samsung HL61A750...looking at the Tru3D kit...(ADVICE/INPUT NEEDED) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-23-2012, 08:33 AM - Thread Starter
jhill1977's Avatar
I currently have my Samsung HL61A750 hooked up to a Panasonic DMP-BDT310 3D Blu-ray player and 3-pin IR emitter and pair of active shutter glasses from from Ultimade3dheaven.com
434
The DMP-BDT310 allows for checkerboard output and the 3D looks pretty good with my current setup.
For those that already have the Tru3D kit..is it really as promised? I'd like to be able to take advantage of more 3D sources, particularly 3D broadcast TV and Comcast 3D on demand, and understand I need to convert the "side by side" 3D to the "checkerboard" format my TV can handle Will the Tru3D kit work with my current setup? I'm hoping I can simply re-use my existing emitter and 3D glasses and simply buy the "Samsung 3D TV adapter kit" for $240.
275
It does seem like a lot of hoops to jump through to get 3D on my LED DLP, but I'm not in a position to spend $1500+ on a new 60 inch 3D LCD or plasma TV, especially when my DLP still works great.
jhill1977 is offline
post #2 of 4 Old 06-29-2012, 09:40 AM
jesmer's Avatar
Quoted: 45 Post(s)
Liked: 25
I have a Samsung Hl50a650 which is a 50 inch dlp that I'm getting rid of, and I have the adapter you need. I believe that tru3d kit is just a mitsubishi adapter with the EID shut off. I am going to sell my adapter for $100 plus $10 for shipping if your interested. The manufacture date I believe is november 2010.
Let me know if you are interested. I also sent you a PM with additional info
jesmer is offline
post #3 of 4 Old 07-02-2012, 06:56 AM
Baley's Avatar
Do you still have this for sale?
Baley is offline
post #4 of 4 Old 07-04-2013, 09:23 PM
CHMATAV's Avatar
434
275
hi Sr, your panasonic bluray display on the option menu the 2d to 3d?
CHMATAV is offline
Reply 3D Source Components
