Splitter for Frame packing for Interlace 1920x1080 60i 3D? - AVS Forum | Home Theater Discussions And Reviews
Old 07-02-2012, 06:20 PM - Thread Starter
W.Mayer's Avatar
Quoted: 220 Post(s)
Liked: 264
since i got the Geo Box 501 i am very happy to see that it is now
very easy to split a frame packing 24p 3d signal from a 3d bd player into
2 separated hdmi outputs to feed a passive 3d two pr. solution.
this unit is a very good tool for this.
i have a sony 3d cam the td20 that can record in
"frame packing for interlace 1920x1080 60i 3d".
sad this geo 501 box can only deal if i switch the output from this 3d cam to
"side by side" means only half resolution this camera than output compare to
the output "frame packing for interlace 3d 1920x1080 60i"!
at my big screen I need this better resolution in 3d.
my question ..is there any other unit out at this time that can split this frame packing for interlace at full resolution
into 2 separated hdmi output at 1920x1080 at 60i or 60p?
W.Mayer is offline
Old 07-25-2012, 11:21 AM
jxl3d's Avatar
If your TV has SDI inputs or if you have Mac with Thunderbolt port you could use Ultrastudio 3D
http://www.blackmagic-design.com/products/ultrastudio3d/techspecs/
If you pair it with powerful external 12v battery you could use this setup (in theory) as 10 bit 4:4:4 external recorder for TD20!
jxl3d is offline
Old 07-27-2012, 06:34 PM
walford's Avatar
The problem with your desired solution is that the two 1/2R 960x1080 fields have to be upscaled with a good upscaler to 1920x1080.
Are you sure your camera does not support ouitputting 2 1920x1080/60 in frame sequential 3D mode.
walford is offline
Old 09-16-2012, 05:44 PM - Thread Starter
W.Mayer's Avatar
Quoted: 220 Post(s)
Liked: 264
yes the sony td 20 can output eather the frame packing for interlace at full hd 3d or a side by side 1920x1080 60i picture
with half resolution nothing more.
to bad i saw some 3d tvs (possible also some 3d pr.!) that told via hdmi the source (my sony td 20) when the sony output talk with the display yes i can display
frame packing for interlace in 3d but the test pattern show that very likely the 3d tv take this frame packing for interlace but
downconvert it to side by side as the resolution test pattern i record show exactly the same as when i feed a side by side picture from the
sony td 20!!!
i can test it very nice as the new panasonic 65" 3d plasma can display for sure the full hd 3d quality that the frame packing for interlace in 3d can record.
so i have a perfect display to check what is possible with the sony td 20 when the display show it right.
i saw this blackmagic ultra 3d but you are sure it can seperate the 2 streams at 2x 1920x1080 at 60i at the hdsdi out?
if so thats my box as i have 2 hd sdi to hdmi converter from blackmagic.
feed my pr. with each a 1920x1080 60i is not any problem they can deinterlace it.
W.Mayer is offline
