Samsung DLP setup for 3D issues HELPPPPPPPPPPPPPP - AVS Forum | Home Theater Discussions And Reviews
Old 07-04-2012, 11:38 AM - Thread Starter
Guarddog32's Avatar
I bought one of those 3D Emitter boxes with 4 pair of glasses on Ebay from the 3DTV Corp company and cant get it to work with either my laptop or sony blu ray as the source.
If I try to set it up with my Dell laptop with nvidia 3D vision built into it (with a built in emitter) I hook up the hdmi port on my laptop to the hdmi3/dvi connector on back of TV, then hook the emitter that came with glasses to the 3D sync out 3 pin connector on back of TV, and when I run the setup on nvidia control panel, it tells me that vesa emitter cable is disconnected or stereoscopic 3D is not turned on on tv. (I went into my TV setup screen and 3D is turned onto mode 1.
I will stop for now so i can get some advice on getting my laptop to work with this emitter and glasses kit. I will ask more later about why my Sony 3D blu ray player wont work either.
My Samsung DLP TV is model; HL61A650C1FXZA
Laptop is Dell XPS L702X, Windows7 with Nvidia Stereoscopic 3D Vision with built in emitter and 3D glasses for laptop
The 3D kit I bought from 3DTV Corp is the Gen2Pro / Home Emitter with 4 pair of Glasses.
Thanks so much in advance for any help I can get with this setup...
Rich J
Guarddog32 is offline
Old 07-09-2012, 09:31 PM
lewis3845's Avatar
Does your laptop have an Nvidia Quadro card? because that's what it says it supports for Nvidia.
lewis3845 is offline
Old 07-10-2012, 08:14 AM - Thread Starter
Guarddog32's Avatar
No, mine is the GeForce GT 550M
