Purchased new panasonic tc-p50gt50, previous glasses are not working? - AVS Forum | Home Theater Discussions And Reviews
Old 07-05-2012, 11:39 PM - Thread Starter
Josh Reighard's Avatar
I just started using my panasonic tc-p50gt50 today and couldn't get my Panasonic (Ty-ew3d3m) glasses to work. These glasses came with the Avatar pack I received with my previous tv. Should they be compatible?
Josh Reighard is offline
Old 07-06-2012, 01:15 AM
Joxer's Avatar
No the previous year's Panasonic 3D glasses used infrared while the 2012 models use bluetooth (RF) so they are incompatible.
However the new 2012 bluetooth 3D glasses models from both Panasonic and Samsung are now compatible with each other's 2012 3D TVs.
The cheapest compatible model with the GT50, is the Samsung SSG-4100GB for under $20 on amazon or at Best Buy stores.
Joxer is offline
Old 07-06-2012, 09:58 AM - Thread Starter
I figured. Actually will work better because I have a soundbar at he bottom of my tv that used to block the infrared glasses.
Have you used the Samsungs?
Thanks for your help!
Panasonic Viera Tc P50gt50 Plasma Tv
