Sony 3D camcorder HDR-TD20V 3D playback from media player not possible? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 51 Old 03-03-2013, 08:16 PM
3David's Avatar
Thanks for your reply. You raise my hopes again. I know of and appreciate your previous pursuit of this matter in that thread.
I HAD read that thread a couple months back, and based on it I even bought a used Sony S580 Blu-ray player off eBay (to replace my S570). When I attached my external hard drive with files copied to it from the TD20V (those very m2ts files which the TD20V can play in 3D from that external drive with no problem), the S580 would not play anything in the AVCHD folder that the camera had created and put them into. The S580 simply would not list the files in that folder at all. What to think/do?? Also, I burned what I thought was an short AVCHD blu-ray disc using Cyberlink 12 Ultra; but the S580 played it only in 2D (just as did the S570). Yet I could import the video FROM THAT DISC back into Cyberlink, and Cyberlink identified it as 3D video, and even played it in 3D in it's viewer function on my computer.
Some of what I have read seems to suggest that perhaps software updates from Sony took away the capacity of the S580 to play 1080 60i 3D files. Also I know the software in the TD20V is different from what was originally in the TD10 mentioned in the thread. Maybe that's my problem?
I truly hope my reply does not seem argumentative...for I really want to find the way to do this. If the answer involves locating legacy software or whatever, I'd go for it, if only I it would actually work.
Got links to specifics that address these particulars? Ideas? Am *I* the problem? I am trying to master what seems to be complicated and rarely/weakly documented issues, but so far I have not succeeded.
3David is offline
post #32 of 51 Old 03-04-2013, 04:43 AM
Wolfgang S.'s Avatar
Quoted: 42 Post(s)
Go to the AVCHD 3D discussion and see there how it works. It makes no sense to do different things like using an harddisc that has NO AVCHD 3D structure. And then you wonder why it does not work.
Kind regards,
Wolfgang
videotreffpunkt.com
Wolfgang S. is offline
post #33 of 51 Old 03-26-2013, 03:13 AM
cipsua's Avatar
Hello.
I'm having the same problems!
I own a Sony HDR-TD20V camera + a LG 3d TV.
I'm a video editor, and i want to make a presentation of a product, in 3D.
1. I shoot in 3D with Sony HDR-TD20V camera
2. I'm downloading the MTS from the 3D cam, on my PC for editing purposese (to make a brief presentation of a product)
a. the MTS source videos, on my hard disk, are 2D FullHD > i tried in Vegas ("converting" in Side by Side mode) to export the movie, and play from a USB STICK on the LG 3d TV > no 3D
b. in whic format do i have to export from Vegas (side by syde?)
3. Or, please, give me another solution for editing videos on PC, for a presentation af a product, and then view that movie on LG 3d TV (how do i export, how to do it)
cipsua is offline
post #34 of 51 Old 03-26-2013, 05:11 AM
Quoted: 42 Post(s)
BEFORE you import the MVC-media into Vegas, you have to set the project propteries to a s3D mode.
If you habe done it the other way round, you can mark all the medias in the explorer windows of Vegas - and then change the media properities to an s3D mode.
Kind regards,
Wolfgang
videotreffpunkt.com
post #35 of 51 Old 03-26-2013, 05:19 AM
cipsua's Avatar
I've allready did the project settings in Vegas to: "Stereoscopic 3D Mode - Side by Side half", resulting in a side by side preview. I've exported the video to multiple formats: mp4, m2v, avc, avi, mp4, but no results (i cannot see on 3D TV, played from a usb stick).
Am i doing something wrong here?
thank you for your answer!
cipsua is offline
post #36 of 51 Old 03-26-2013, 06:14 AM
Quoted: 42 Post(s)
You can export to side-by-side half, and maybe you have to set your HDTV to s3D manually. But I do not know if that works for you hardware.
To what format you export will be a question of your hardware equipment. If you have a 3D-Blu-ray player, you could export to 720 60p (if you come from 1080 60i) or 1080 24p with the Sony AVC/MVC encoder, and create a 3D-BD-ISO from the timeline. Burned to BD-R/RE, you could playback that with a 3D-BD player.
Kind regards,
Wolfgang
videotreffpunkt.com
post #37 of 51 Old 03-26-2013, 07:16 AM
cipsua's Avatar
thank you, i will take this into consideration: buy a 3D BR player.
is there a chance to play from the PC to the 3D LED TV ?
cipsua is offline
post #38 of 51 Old 03-26-2013, 08:32 AM
Quoted: 42 Post(s)
That could work with the Stereoscopic player or PowerDVD.
Be aware that side-by-side half can be played back with every 2D-BD-Player or even DVD-Player - if you are able to switch your 3D-HDTV to sbs-half (what should work). So if you render your s3D footage as sbs-half it should work with stick, 2D-BD or DVD-Player.
A 3D-BD would have the advantage that you will not loose 50% of the resolution as it happens with sbs-half, but that you are able to playback 2x1920x1080 if you use 1080 24p.
Kind regards,
Wolfgang
videotreffpunkt.com
post #39 of 51 Old 03-28-2013, 01:58 AM
cipsua's Avatar
I've found out what the problem was:
When i've imported in Vegas the s3D video, i didn't "pair the subclip" (option that i didn't know that i had to select).
SO, the correct way is: (advice for a new user with the same problem)
import in vegas the s3D video
select "yes" to match the project settings to the videos settings
in project settings, select "Side by Side Half" (if you want to play on a 3D TV)
on the time line you will have the impoted video(s) > in the time line there are one on each other two representation of the video > select that 2 "layers", right click and select "pair as stereoscopic 3d subclip"
only now the side by side image is correct !!! untill you select that 2 "layers", right click and select "pair as stereoscopic 3d subclip" the side by side image is not correct (what is in the left, is in the right too...)
then you export to which format you like ( i did AVCHD > mts / m2s) > copuy on stick > play on 3D TV.
Thank you Wolfgang S. for your answers!
cipsua is offline
post #40 of 51 Old 03-28-2013, 05:41 AM
Quoted: 42 Post(s)
That is still a limited underständing. For Vegas it is important only, IF you have any s3D mode enabled in the project settings BEFORE you importh the footage. That can be anaglyphic, side by side half - whatever you like.
For the MVC footage of the TD10/20/30/Z10K, there is no pairing required as long as you follow the rule above. Pairing is required only if you shoot your footage with two different cameras.
Kind regards,
Wolfgang
videotreffpunkt.com
post #41 of 51 Old 11-23-2013, 11:31 AM
KeithLoving's Avatar
Hi all,  I am thinking about buying the HDR-td30v model, it is the current sony 3d hd video camcorder....anyhow,
does anyone know if I can take my recorded video files straight from the sd card, out of the camcorder and will the file be able to be played back on this 3d blu ray player?
Panasonic - Smart 3D Wi-Fi Built-In Blu-ray Player
Thank you if you can provide some insight....
I want to totally skip/bypass the PC and software experience of needing to convert any files....I don't consider that part fun.
Looking for plug and play here, can I eject the card out of my camcorder and insert the card into the above mentioned blu ray player and get 3d play back that one would expect?
there is another 3d blu ray player here which I like less will this one also work?  http://www.bestbuy.com/site/samsung-smart-3d-wi-fi-built-in-blu-ray-player/9422045.p?id=1219016114223&skuId=9422045
Thanks all.  I am on the market to buy both a 3d blu ray player and a 3d hd video camcorder...just looking for compatilibty between the devices that plays same file types in 3d and 2d.
Also, anyone know if I can copy contents off of an sd card into an external hdd using the Panasonic Model: DMP-BDT330?  it would be a great way for me to archive my videos...thanks again
KL
KeithLoving is offline
post #42 of 51 Old 11-24-2013, 03:36 PM
ronison's Avatar
Hi, I´m in the same dilemma (having TD20) but for now am a step further.
Yes and no, the Panasonic BDT330 will probably play the files in 3D directly from the SD card like many other Panasonic players do. That means that you can´t copy the naked files to another card, you must have the original folder structure from the camera. I already tried to rebuild this structure with tools (don´t remember the name) but only got 2D from that.
I didn´t try the BDT330 but a friends BDT130 and BDT500 as my BST720 recorder. There are some shortcomings with these: You can not address a clip directly from a menu with these players using the original Sony SD structure (exports from EDIUS 7 work). The BDT130 can´t skip "automatically". You have to repress the skip button to get to the next clip. With the BDP500 and BST720 you can hold the skip button and the player skips through the files automatically. I also had a Sony S4100 here but don´t remember the behaviour exactly. I only know it plays the files using a card reader from the original SD structure in 3D 1080i (don´t ask me for the resolution, didn´t test that).
With the BDT500 and BST720 there is another weak point. Both players send signals using 3D 1080i (no more info), but the result is not the FullHD picture. I generated a testchart using EDIUS 7 and found that resolution comes shorter compared to play the same file in 2D! I´d say it´s about the half horizontal resolution but still usable.
There could be another way for you, a media player, but as nothing is perfect I´m still on the search here, too. Many players using a Realtek 1186 chip play these videos without the need of the folder structure, means you can copy several files to one card using a computer and play them back with the player. My last buy was a fantec 3DAluPlay (don`t get the 3DFHDL since it does´nt play your 3D files). This player as the Mede8er X1000 3D and others play the Sony 3D files "only" in 720p. BUT the horizontal resolution is visibly better than that from the Panasonic players above. The vertical resolution is slightly better with the Panasonics but in the end I´d give the fantec/Mede8er the edge. Don´t get me wrong, most people will also be happy with the Panasonics.
Maybe, if you don´t want a computer a Panasonic BST/BCT recorder could be your best buy since it can do simple edits with your files and save them to the internal or an external HDD (which can´t be used with a computer after formatted with the recorder as far as I know, didn´t try yet).
For me I´m still on the hunt for a better mediaplayer, maybe the Dune 303D can do what I want. The popcorn hour A-400 doesn´t do that with the latest official release but seems there is some motion in development...
Hope that helps...
Roland.
ronison is offline
post #43 of 51 Old 11-25-2013, 02:56 AM
Quoted: 42 Post(s)
What Edius 6.5/7 does is that it exports an AVCHD 2.0/3D compatible structure - and that can be read from every AVCHD 2.0/3D compatible 3D-Blu-ray player (typically the newer units of Sony and Panasonic).
See the AVCHD 2.0 thread that we had here.
Kind regards,
Wolfgang
videotreffpunkt.com
post #44 of 51 Old 05-31-2014, 11:50 AM
Valentinov's Avatar
Did anyone ever had an issue with td10, 20 or 30 that one camera is out of sync/focus with another? Right camera is out of focus 50% of the time (I own td20). "Auto 3D Lens Adjust" doesn't solve the issue. I can't figure out what triggers such behavior.
Valentinov is offline
post #45 of 51 Old 08-23-2014, 08:31 AM
Liked: 0
Originally Posted by 3David View Post
I've owned a Sony HDR-TD20V since 4/2012, and like nycpaull I have been blown away by the quality of 3D played directly from the camera, viewed on a 47" LG 3D-TV. My videos are of grandkids and of retirement travel. Watching this way is as close to reliving as anything I have ever seen.<br><br>
But I won't be really be satisfied until I can edit video using software like either my Sony Studio 12 or my Cyberlink Ultimate12 programs to add music, transitions, titles, etc. and put them on a disc that can be played on some 3D player (I have blu-ray) to view without losing ANY of all that native high resolution!! (Rendering to current Blu-ray discs is disappointing, sometimes even jerky when subject motion is moderate-to-quick.)<br><br>
Until the means to do that becomes available, I will just use a &lt;2 TB USB external HD for storage and playing back, as discussion on this thread has highlighted.<br><br>
NOTE my main reason for posting: With that option in mind, I want to pass on a tip that the Toshiba Canvio Plus hard drive is really ideal. It comes in a 1.5TB model that measures only 4" X 3.5" X 5/8" and runs totally off the USB connection for its power. Perfect! It fits right in my camera pack with my TD20. Also note, Radio Shack (really!) has it on sale this week for $100, down from $119. After I backed up the Canio's NTSC preloaded software into my computer (should I ever need it in the future), I let the TD20 camera reformat the drive to FAT-32 and copy all its files to it. I was easily able to insert each of my accumlated SDHC cards in the TD20, and repeat the back up process to the Canvio. The camera detected what files have not yet been put on the external HD, and copied only those to the external drive.<br><br>
(Still, I wish I knew how to motivate Sony/Panasonic to provide software/upgrades for editors, players, and/or computers to play back m2ts files in full resolution/5.1 sound! With the price drop of the new Sony TD30, 3D camera sales should really jump and add to the numbers of consumers wanting this problem resolved. Petiton???)
3David,
It was with great interest that I read and re-read most of this whole thread about viewing video on these amazing Sony 3D cameras. Being an old Stereo Realist buff for 20+ years (till film died out and I was sorta left high and dry 3D wise) I am more than amazed at the video quality of my HRD-TD30V camera. Great, but I am having a BEAR of a time trying to get an external hard drive going and dumping everything on there so I can free up my cards (which is the only thing I'm watching so far).
OK, my predicament:
I have a:
Mac computer, 5 year old (Intel based) G5 tower
WD 1.5 TB hard drive
46" Sony 3D Bravia TV
I thought I had done all the reformatting jazz on there OK, but when I put on a copy of a 3D file on to play around with and see if the camera would recognize the drive...... nothing. I AM NOT technically proficient AT ALL (Goo-Goo Gaw-Gaw is about as deep as I go) so this is beyond frustrating. Can anyone out there tell me how I can simply unload my cards onto the drive and then view them off the new external hard drive? Sounds simple enough, but I guess not to me. Thank you so much in advance for ANY info. Larry
LarryLandolfi is offline
post #46 of 51 Old 08-23-2014, 10:15 AM
Valentinov's Avatar
Here is an experience I had with td20. I bought it used for $700, it was claimed to be a display item. Condition was prestine, and I worked. Once lenses were out of focusing synch from time to time, but Sony didn't find the problem. And month ago screen gave up and became unresponsive. Soon wanted $600 to replace the main board. I refused. Instead, I'm using remote to do everything I would otherwise do on the screen.
When it comes to media, I download files into the computer, and then import it all into Vegas. From Vegas I export (render) the footage twice: as 2D and as 3D side-by-side. Then, in Premiere, I crop out unnesessary video, add titles, music, transitions, etc., and save footage as 2D movie. Then, I replace the 2D footage with 3D. Since they are the same, I don't have to do editing again (except for titles). Then I save movie which I can play on 3D devices.
One problem: camcorder records at 30fps, but my projector (and may be other devices as well) don't play 3D HD in 30fps but 24fps. So when I try to do so, the video is jerky during panning and other similar camera movement (due to conversion of 30fps into 24, so 6 frames have to be dropped somewhere, somehow). To overcome the problem, movie has to be played at 720p.
post #47 of 51 Old 08-23-2014, 10:53 AM
3David's Avatar
Larry,
Although I have been using computers since 1984 and the days of C:> prompts, I find that it has been difficult for me as a rank amateur to acquire the knowledge I need to understand fully how video files are constructed, and the related issues of modifying them, storing, playback, etc. AVS forum has helped, although some members' responses seemed impatient and condescending, which has inhibited my pursuits here a bit. (Testy forum members need to recognize that one is acknowledging one's ignorance--no crime, at that-- in even asking a question.) Be aware I am not a technician, and I am therefore limited to merely sharing with you my best understanding of what I have experienced in trying to do what you are apparently trying to do. All that said, I hope this reply helps you with your question.
The process apparently has to be one in which the CAMERA must put the files onto the external Hard Drive (eHD). I've had no luck getting 3D playback of files put on an eHD directly from a computer. That means I can archive all my SD cards through the camera to the eHD, but not anything I have processed on my computer. Frustrating, isn't it?! Seems Sony has just ignored HRD-TD10, -20, -30 customers in our obvious need for software and players to handle HD-3D editing of files produced by their TD video cameras, to maintain the full 60 fps HD-3D experience that has so impressed you and me.
So, the way to archive all your SD cards onto your eHD is to start with an unformatted eHD. Plug it into your camera and let the camera format the eHD. Then, it will ask to copy files from the camera to the eHD. It will copy all files from the camera's internal memory as well as from the SD card. After all the files are copied, you can play full HD 3D 60 fps files from the eHD by using the camera as the player. To add additional content to your eHD from your other SD cards: power off the camera leaving the eHD still plugged in to the camera; swap into the camera a yet-uncopied SD card; power on the camera and it will again recognize the eHD and ask if you want to copy files; instruct it to copy the files, and it will search for any SD card files not on the eHD and copy them to it. Repeat this process until all your SD cards have been copied to the eHD. It seems a bit laborious, and it affords no opportunity to edit or add titles, etc., but at least you can have a complete archive.
The issue seems to be that the Sony camera sets up its own database for the eHD, which allows it then to play the files in full HD-3D 60fps. Adding files you have worked with on computer apparently will make the eHD no longer fit the camera's database information, and the camera does not play the files correctly.
You may have to google to find an application to get your current eHD back to a blank, unformatted state to begin the process I describe above.
BTW, my dedicated 1.5 TB eHD just filled up after 2.5 years of shooting home videos. This is not a cheap hobby! But I still love my camera and 3D videos. Someday yet I'll surely find software and hardware needed to edit/store on ordinary disc media and play back easily these terrific files!
David
3David is offline
post #48 of 51 Old 08-24-2014, 05:45 AM
Liked: 0
David,
Thank you SO MUCH for all the wonderful information on my dilemma. You're not a "rank amateur" in my book, that's for sure.
OK, so I have to get the files onto an unformatted eHD. I already formatted it to my Mac, and even when I hooked it up to the camera (and hooked up to the 3D TV with a single practice movie loaded on it) it asked me again if I wanted to format the Hard Drive and that all the info would be lost. What on earth was I to do? I said yes, format it again. I unhooked it, brought it back to my Mac, dragged on that practice movie again and hooked it up to the camera / TV. Then I'm getting all these "do you want to copy these photos?" prompts. I said yes, and the thing started to copy. I had no idea what that meant or what I was doing. There was just one practice 3D movie file on there so what the heck. When I saw the time that it was taking to copy, I'm asking myself, "Is this copying this file at 1X speed (a half hour movie would take half an hour to copy)? It was really, really going slow. Against the prompts advice I did pull the USB plug out (since I saw no way of stopping this process) and have been totally frustrated since.
Maybe in the future I'll do the Sony Vegas thing, but for right now I'm just trying to empty SD cards onto an external hard drive, hook the hard drive up to the camera hooked up to my Sony 3D TV, and play them. The end. WHY does this have to be so torturous?
You say I should probably unformat my external hard drive and start from scratch again.
At this point that might seem like building the Great Pyramids of Cheops to me. I guess I have no choice. Oh how I wish I could just talk to someone in "real time" about this. Larry Landolfi (Rochester, NH)
post #49 of 51 Old 08-28-2014, 01:19 AM
Liked: 0
4K Download
I know 4K Download is one of the best tool in the current market to download and play 3D videos. Here are more information
https://www.4kdownload.com/howto/how...yback-3d-video
Joseph Chacko is offline
post #50 of 51 Old 08-29-2014, 03:47 PM
Liked: 0
One Last Thing
David, Joseph, All Others,
Thanks for all the wonderful information. I finally figured out how to download my videos onto a portable hard drive and am able to view them all. But one last thing, though, and this seems to be HUGE.......
When I first got the camera I downloaded the videos onto a hard drive next too my main Mac tower (G5). I then erased (formatted) the cards and shot more stuff on there. I am having a wicked time trying to load these original videos back onto an SD card to view them on my camera / TV set up. I have tried EVERY combination of loading these things, even straight to the personal HD, again, under every possible combination (even naming them differently) but for some reason the Sony 3D video camera won't recognize them on the HD. I see that they go onto the SD card, or the HD, but I'm guessing that when I downloaded them onto my Mac desktop they became something "else" and now my Video camera won't play them. This is super important to me. Thanks in advance for anyone's help. Larry
post #51 of 51 Old 02-28-2017, 02:47 AM
Liked: 0
External storage problem and audio question
Thats a really fine thread and now after 3 years I hope to get even more information from the nice members of this forum:
I own a Sony HDR-TD20V and have tried the Brorsoft MTS converter to get side by side conversion to mkv format. But the quality is not good even if its a professional software for 39 bucks. Ghosting and bad images are all over the converted movies. Any suggestions what I do wrong?
In addition I copied 3D files to an external drive but lost the adapter and copied them afterward through windows to another hard drive. The Sony camera is not able to
read the pictures and movies on the 2nd harddrive (I have formatted it before using it with the camera internal formatting programm). It tells me it cant find any pictures. What I am doing wrong?
What can I do to preserve all gps information on the hard drive so that the camera can directly use the movies from external drive and play them?
During playing videos I hear the sound of the camera louder then from HDMI- how can I change that?
Best regards
Micael
Micael is offline
Reply 3D Source Components
