3D Blu Ray Playback from PC to 3D TV, cannot get it to work... help needed! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-14-2012, 03:31 AM - Thread Starter
dbgt's Avatar
Ok, so im very new to this. I have read a lot trying to figure this out by myself... but i think is time to ask
I have my PC GPU (GTX 570) connected through HDMI to my HT 3D ready Onkyo S5400, which is then connected to my 3D Samsung TV (LN55C750) via HDMI.
The PC is also connected to my Monitor through DVI, so i have dual monitor
Ive never had any problem with this components, i got Powerdvd 12 Ultra and tried to play a BD 3D, i extended the display and selected the TV as the main display.
Powerdvd recognize my TV, and even when i click the option to enable 3D, the tv screen flickers and changes to 1080p 24p, but nothing happens...... no 3D... the movie is display in regular 2D
I dont have Nvidia 3D TvPlay and i have read that i dont need it to play 3D BD, only for 3D games.
What can i do?
Any help will be really appreciated.
Thank you very much
dbgt is offline
post #2 of 3 Old 08-15-2012, 07:22 AM
rekbones's Avatar
Quoted: 408 Post(s)
Liked: 198
I think your problem is dual monitors. If your Monitor is not 3D then PowerDVD won't play 3D. Try unpluging your monitor and I bet it will work just using the TV for display
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #3 of 3 Old 09-05-2012, 01:33 PM
Craig Woodhall's Avatar
I can't speak to the posters problem but i have an ATI card attached to both my 2d LCD monitor and also my Samsung 3d plasma and it works great.
Craig Woodhall is offline
Reply 3D Source Components
