Help with ps3 3d - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-17-2012, 08:09 AM - Thread Starter
GB_KSU's Avatar
My father in law purchased a new 80" sharp flat panel that we installed the other day. He has a fat 60gb ps3 as a blurry player. I did a firmware update on it and we are unable to get 3d discs to play. I am wondering why this is. We have the ps3 connected to his Onkyo receiver via hdmi and hdmi from the Onkyo to the tv. I don't know the model number exactly of the Onkyo it's about four years old and I think it was the 8xx series. Does the hdmi need to be run directly to the tv??
GB_KSU is offline
post #2 of 6 Old 08-17-2012, 10:22 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Is your AVR HDMI 1.4? It may not pass 3d if only 1.3. Are your HDMI cables hi-speed?
lovinthehd is offline
post #3 of 6 Old 08-17-2012, 01:38 PM
BleedOrange11's Avatar
Try resetting the video settings with the "Automatic" option. I had to do that the first time that I used 3D. HDMI 1.3 works with 3D for PS3s and Xbox 360s.
BleedOrange11 is online now
post #4 of 6 Old 08-17-2012, 02:03 PM
lovinthehd's Avatar
Liked: 4775
My 1.3 AVR would not pass 3d signals from my PS3 or DirecTV box....but I've read where some AVRs do. YMMV.
post #5 of 6 Old 08-18-2012, 02:31 AM
rekbones's Avatar
Quoted: 408 Post(s)
Liked: 198
If your AVR is 4 years old it most likely is not HDMI 1.4. The great thing about the PS3 is its not really 1.4 either. If you connect the PS3 directly to the TV and run the setup again it should setup 3D then reconect it to your AVR, as long as you don,t run setup again it should work in 3D. The PS3 does't check for a 3D device every time it plays a 3D game or Blu Rays as all other players and SAT/Cable does.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #6 of 6 Old 08-24-2012, 09:57 PM
bubbaba's Avatar
With my older Onkyo I was able to run the setup as it was directly connected to the projectr/tv and get it to recognize 3D. I then reconnected to the AVR, however my AVR would only pass 3d games and 3d from VUDU. I was not able to play 3d blu rays as these are a different format. So you may be able to get games and VUDU but I finally upgraded my AVR to get 3d blu ray.
bubbaba is offline
Reply 3D Source Components
