Using the correct 3D convertor? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-19-2012, 05:46 PM - Thread Starter
DesertSkyy's Avatar
I just got an optoma pro360w projector. I found out it is 3D capable so I got a 3D bluray dvd player.
I'm now learning there needs to be a convertor between the two.
Is there a convertor that will work for use with the projector AND my 2D HDTV?
DesertSkyy is offline
post #2 of 3 Old 08-20-2012, 06:14 AM
ToneCmdr's Avatar
Check out the HD Fury 4. I don't have one myself but I'm tempted to buy one.
ToneCmdr is offline
post #3 of 3 Old 08-20-2012, 06:19 AM
threed123's Avatar
Liked: 39
There are a couple of converters available. The Optoma 3D-XL comes to mind and you can search it out on AVSFORUM/Amazon. It converts 3D between a 3D game player or 3D bluray to a 3D capable projector, but will not create a 3D image on a 2D TV. If all you want to do is watch 2D from your 3D blu-ray player, then you won't have a problem anyway, just plug it into the 2D HDTV. The player will put out a 2D signal. If you want to watch 3D on a 2D TV, there is a converter that will do that, but I've used it and it does a poor job--lots of flickering and ghosting from my experience. You can search for that as well in these forums.
Edit Note: I have not used the Fury, but it looks interesting--pricey though. The site says it is not recommended for 50/60 hz LCDs--which, I'm guessing is what your 2D HDTV is.
threed123 is offline
Reply 3D Source Components
