In need of a 3d player - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-02-2013, 08:09 AM - Thread Starter
Bellamy's Avatar
Hi I need to get a new 3D blu-ray player that can output 3D/1080p from the HDMI while also outputing a HD signal from the componant output. This does not need to happen at the same time but I dont want to have to go into the menu functions and switch something on or off. Maybe this is a common thing or maybe none can I'm not sure.
Thanks for your advice.
Don't be Cheap, It costs that much for a reason. You really do get what you pay for.
Bellamy is offline
post #2 of 2 Old 01-27-2013, 04:04 PM
tucsondave's Avatar
I don't think you'll find such a thing. Because of the "Analog sunset" starting in 2011 and ending in 2014 BD players are not allowed to
output HD analog. Some players don't even bother with component or composite outputs anymore. My 3d Panasonic BD manufactured in 2010 has both.
My new Oppo has neither.
"We're from the government and we just want to help you."
td
tucsondave is offline
Reply 3D Source Components
