3D Adapter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-27-2013, 07:19 PM - Thread Starter
debbiedarby25's Avatar
I have the Mitsubishi WD-65C10 3d ready tv along with the Panasonic DMP-BDT220 3d blu ray player. Do I still need the adapter to watch 3D? If so, what is it I need to buy. If not, I can not figure out the settings to watch 3d movies eek.gif
debbiedarby25 is offline
post #2 of 3 Old 01-28-2013, 12:47 PM
Rudy1's Avatar
Quoted: 966 Post(s)
Liked: 1280
You won't need an adapter or emitter if you choose to go with DLP LINK glasses instead of IR. First of all, make sure your TV has the latest firmware (version 12.02, available from the Mitsubishi TV website); go into the TV's menu, highlight 3D Mode and select ON. Then highlight DLP LINK and select ON (more detailed instructions are available on page 13 of the TV's manual). In the Panasonic's 3D menu, set it to output CHECKERBOARD format, and you will be able to watch 3D Bluray movies.
debbiedarby25 likes this.
ASKHOLE: (n.) A person who constantly asks for your advice, yet always does the opposite of what you told them.
Rudy1 is offline
post #3 of 3 Old 01-29-2013, 10:32 AM - Thread Starter
Thank you soooo much!!
Reply 3D Source Components
