How can I film a 3D video with Sony HDR-TD10 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-14-2013, 07:41 AM - Thread Starter
Pier9's Avatar
Hi,
I'm absolutely new at 3D Filming, and i've been working on this project where i must use the Sony HDR-TD10 (The silver one) to film 3D videos and play it on a NON-3D Projector for an audience. I was thinking about Anaglyph? or is there any other out there? since the projector is non-3d and the glass is very cheap. Is it possible? and if so, how can i film it using that camcorder? or if it's anaglyph do i even need the 3D Camcorder at all?
Pier9 is offline
post #2 of 6 Old 02-14-2013, 08:17 AM
Don Landis's Avatar
Quoted: 1313 Post(s)
Liked: 373
This is pretty easy. Anaglyph Red / cyan is the universal stereoscopic system to use when you are showing on a 2D TV or projector.
Shoot your video in 3D using your TD10 camcorder. Edit your video in Sony Vegas. Render the completed video to an HD output using anaglyph red / cyan such as Windows Media Video and set the 3D Stereoscopic mode to Anaglyph (red/cyan) under the Project tab. Now render and play the file with Windows Media Player to your projector in full screen. Any laptop connected to the projector will work. Your audience will need the red/cyan glasses.
Understand that anaglyph will subdue the colors and with a projector you will need a dark room or the 3D may get washed out.
My 3D videos and more
Don Landis HT System: Projector Sony VPL VW665ES Players: Samsung UBD K8500 OPPO BD93 Sony BDP S6200 All Regions Player Denon AVR 4311ci, 7.1 JBL Professional series and Klipsch PS3, XBOX360, Dish VIP722K; 3D Edit Suite: Edius7.53, Vegas Pro v13, Power Director15, i7-950, LG 3D TV DM2752
Don Landis is offline
post #3 of 6 Old 02-14-2013, 09:39 AM
relaxman's Avatar
Quoted: 32 Post(s)
My experiences in the past: don't render directly to anaglyph. Video compression don't make any good for red-cyan colors.
Instead render to separate left-right video, or even side by side, and play with some 3d player.
Stereoscopic player, Powerdvd, Bino, etc.
Final projected quality would be a lot better.
relaxman is offline
post #4 of 6 Old 02-15-2013, 09:22 PM - Thread Starter
Pier9's Avatar
Pier9 is offline
post #5 of 6 Old 02-15-2013, 09:24 PM - Thread Starter
Pier9's Avatar
Okay.. If it's like that, how can I or my audience view it? What glass is required? And would it still work on the Non-3D projector?
Pier9 is offline
post #6 of 6 Old 02-15-2013, 09:56 PM
relaxman's Avatar
Quoted: 32 Post(s)
Set those player viewing method to red-cyan anaglyph mode, so you will see 3d with regular projectors too.
Only you avoid video recompression, which is bad for anaglyph (chroma subsampling if you want to know exactly)
relaxman is offline
Reply 3D Source Components
