3D and HD audio with an older av receiver. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-03-2013, 07:10 PM - Thread Starter
abxnightpilot's Avatar
I have a Dell XPS 7100 with a ATI Radeon HD 5780 graphics card. The graphics card has an hdmi and dvi out as well as an additional output that looks similar to an hdmi. I currently run the video thought an hdmi cable directly to my Samsung tv and the audio through an optical cable to my av receiver. I do this because my Onkyo TX-SR607 av receiver won't pass through 3D content so I run the 3D content directly to the tv. The problem is that I'd like HD audio and even if I bitstream I don't get it with the optical cable. My idea is to run the video directly to the tv through the DVI and the audio directly to the av receiver through the hdmi. I have a few questions:
1 Will splitting the signal have any consequences like reduced video/audio quality?
2 Will it increase the operating temperature of my GPU?
3 Is there a better way to get 3D content to the tv and HD audio to the av receiver without buying a new one?
Thanks!!
abxnightpilot is offline
post #2 of 3 Old 04-06-2013, 09:16 AM - Thread Starter
Anyone?
post #3 of 3 Old 04-07-2013, 06:38 AM
rekbones's Avatar
Quoted: 457 Post(s)
Liked: 228
no
I don't think so
buying a new one?
no
Thanks!!
The big question is will it work ? I don't know but it won't cost you much to try it. The HDCP hand shake may cause problems because there is no video on the HDMI. So it most likely won't work.
That third port is dells graphics port and needs a graphics adapter
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is online now
Reply 3D Source Components
