Nvidia 3D Vision on a 2D Plasma? MAYBE! (85hz & 120hz) Refresh Rates - Works!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-20-2013, 06:25 PM - Thread Starter
Jonathan Hersey's Avatar
So I was able to make forced refresh rates of (70hz - 120hz) on my Panasonic Plasma with Custom EDID timings... Anything higher than (70-85hz) on Progressive formats caused screen waves and frequency shaking "distortion".
1920x1080i (Interlaced) @ 120hz
1280x720i (Interlaced) @ 120hz
1920x1080p (Progressive) @ 70-85Hz
1280x720p (Progressive) @ 70-85Hz
So now I wonder to myself something...
I wonder if the nVidia 3D vision Kit I am getting soon would work on this Plasma! smile.gif
http://www.nvidia.com/object/3d-vision-system-requirements.html
All nVidia says you need is a 120hz capable display + 3D Vision kit and glasses + nvidia GPU + PC
MAYBE! I just wonder If I could get Nvidia 3D vision to accept the 1080i,720i 120hz signal?
MAYBE! if it could just accept the beefier 70-85hz modes for 1080p,720p?! biggrin.gif
Honestly my Panasonic has great interlacing/interlacing tech performance... I couldn't really tell the difference between the 1080i 120hz and 1080p 85hz as far as picture quality goes.
Check this site out. LOTS of people are testing their TV capabilities with EDID edits and custom timings only to find hidden supported refresh rates! biggrin.gif
Any thoughts on this and if there is a way to make custom resolutions and timings for Nvidia 3D Vision?
Jonathan Hersey is offline
post #2 of 3 Old 06-25-2013, 04:18 PM
threed123's Avatar
Liked: 39
I'm not an expert by any means, but I have tinkered around 3D on the PC for years, and this is my thinking. You really aren't getting 120hz on you plasma that would be 3D complaint, just what appears as a phony 120hz by dividing 1080p in half time 2. In other words, you are forcing 1080p at 60hz to look like 1080i at 120hz. Problem with that is a 3D source forces a left eye at 1080p at 60hz and a right eye 1080p at 60hz, therefore getting 120hz left/right eye 3D image. I believe if you get it too work you would have issues per this post:
http://www.tomshardware.com/forum/301267-33-vision-60hz-monitor
threed123 is offline
post #3 of 3 Old 07-01-2013, 07:06 PM
RonAlam's Avatar
Quoted: 12 Post(s)
Liked: 30
wont work, plus it can potentially damage the screen
RonAlam is offline
Reply 3D Source Components
