Help setting up powerdvd to play 3d content on optoma hd131xe - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-23-2014, 10:33 AM - Thread Starter
xorxhs's Avatar
I recently got optoma hd131xe and I need help setting up PowerDvd to play iso files (or any other 3d format). I use my pc (Ati 7950 vga card). When I mount the iso I try to play it with powerdvd, but it only diplays at my monitor and not in projector. Any ideas how to configure powerdvd's settings to make it work?
3d glasses: http://www.ebay.com/itm/130884707051?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
xorxhs is offline
post #2 of 9 Old 01-23-2014, 03:28 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
I would guess it all depends on how you have the projector and monitor connected. Is the monitor 3d capable? The easiest test would be to unplug you monitor and use the HDMI 1.4a to the projector only and see if that works. Setup of dual monitors can be tricky and especially for 3D.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #3 of 9 Old 01-23-2014, 03:37 PM - Thread Starter
xorxhs's Avatar
monitor isn't 3d capable and its connected through dvi cable and not hdmi. Its kinda frustrating not being able to project 3d content.
xorxhs is offline
post #4 of 9 Old 01-24-2014, 06:00 AM
Rudy1's Avatar
Quoted: 964 Post(s)
Liked: 1277
Your graphics card should allow you to set up your connected displays via the Catalyst software. There is a setting that will let you select which is your primary display for Windows, and you should set the projector as such. You shouldn't need to do anything with the monitor at all. Check all of your settings again to see if you missed something.
ASKHOLE: (n.) A person who constantly asks for your advice, yet always does the opposite of what you told them.
Rudy1 is online now
post #5 of 9 Old 01-25-2014, 02:31 AM
ashyt16's Avatar
Quoted: 37 Post(s)
I wouldn't use powerdvd anyway when mediaplayer hc is better and free and the only media player you will ever need.
You obviously have the monitor set up as primary display. Either disconnect it or go into the card settings and enable the PJ display output.
ashyt16 is offline
post #6 of 9 Old 01-25-2014, 05:29 AM - Thread Starter
xorxhs's Avatar
I managed to send output to projector, enabled 3d on powerdvd, set vesa link on projector, turned on my glasses
but still cant see any 3d. Do I miss something? Seems it plays on 2d all time.
xorxhs is offline
post #7 of 9 Old 01-26-2014, 02:03 PM
ashyt16's Avatar
Quoted: 37 Post(s)
Not sure how the optima works but there should be no need to enable anything on the player or graphics card. They simply provide the image data to the pj. It should be a simple case of play 3d movie then select correct 3d setting on PJ. The PJ takes care of the 3D part. If its a sbs movie and not a bluray then you may need to enable sbs manually in the 3d settings of the PJ.. this is how it all works on my Epson.
ashyt16 is offline
post #8 of 9 Old 01-26-2014, 02:17 PM - Thread Starter
xorxhs's Avatar
 I had to have only one display ON, projector;s one. Not even extended one. Just one output only. Thanks! Now need to correct 3d settings, seems yellowish
xorxhs is offline
post #9 of 9 Old 02-20-2014, 12:31 AM
fxrh's Avatar
Quoted: 45 Post(s)
Liked: 52
Here are the settings that work best for me. I use RF glasses (Optoma ZF2100), so I can't vouch for those with different glasses. I also have an Optoma HD25-LV and am simply assuming that the default settings on the other recent Optomas are the same or very similar.
Go to the 3D (default) mode and change the following color settings:
Red no change
Green no change
Blue from 0, 0, 0 to 0, 0, 25
White from 0, 0, 0 to -16, -16, 25
Cyan no change
Magenta no change
Yellow no change
(All other 3D settings no change)
The 3D default settings are automatically saved to the User settings. (Be sure the projector is displaying a 3D signal before making the above changes, otherwise those changes are associated with 2D.) This should get rid of the yellowish tint (very noticeable on black-and-white 3D movies like CREATURE FROM THE BLACK LAGOON).
If you now alternate the projector mode between 3D and User after making the above changes, you'll see a big difference. If you switch back and forth while watching color 3D, the changes may not be noticeable in all scenes, but in black-and-white 3D the difference is very obvious. The 3D settings will have a much stronger yellow tint than the User settings.
fxrh is offline
Reply 3D Source Components
Optoma Hd131xe Dlp Projector 3d
