Video Binoculars - Who's Got Em? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-07-2014, 03:55 PM - Thread Starter
tomtastic's Avatar
Quoted: 866 Post(s)
Liked: 305
Anyone shooting any 3D with video binoculars?
Sony Dev-50
Specs: Click to expand
Spoiler!
1/3" sensor, 25x zoom, 20mp stills, a bit pricey at $2k, but it's very portable which I think is its biggest advantage. I haven't read much on them, but would these make a nice 3D camera? Fixed lenses so not great depth at distance.
Some cheaper ones out there. Sony Dev 3 priced at $650.00, only 10x zoom but it does 1080 60p 3D.
Anyone here have one?
Sony DEV 3
Spoiler!
tomtastic is online now
post #2 of 9 Old 07-08-2014, 06:43 AM
Don Landis's Avatar
Quoted: 1313 Post(s)
Liked: 373
I have regular optical binoculars that also has a video and still shot recording to an SD card capability. It doesn't do 3D and doesn't use the binocular optics for the camera. I rarely use it except as regular binoculars.
My 3D videos and more
Don Landis HT System: Projector Sony VPL VW665ES Players: Samsung UBD K8500 OPPO BD93 Sony BDP S6200 All Regions Player Denon AVR 4311ci, 7.1 JBL Professional series and Klipsch PS3, XBOX360, Dish VIP722K; 3D Edit Suite: Edius7.53, Vegas Pro v13, Power Director15, i7-950, LG 3D TV DM2752
Don Landis is offline
post #3 of 9 Old 07-08-2014, 05:12 PM
Predator - Brian
Jet-X's Avatar
Quoted: 18 Post(s)
I have the DEV-3. Shot a ton of footage including cockpit footage from the last passenger DC-10 to fly.
It's a 10x zoom for 2D, and a 5x zoom for 3D. And it does 60i in 3D, not 60p FYI.
Pretty happy with it, it's a Sony TD10 in binocular form. I did bring an attached monitor and HDMI cable so I didn't always have to look through the viewfinders to record. However, I found that the monitor would often trip the camera from 3D to 2D when I hit the record button, so I stopped using it for the duration.
Overall generally happy with it, did ok in low light. I was going to buy the DEV-50 but read quite a few issues with the 3D alignment/lenses so went with the DEV-3. But it gets heavy after a while, and would like to find a DEV-50.
Over in Japan, there is a DEV-3 equivalent of the DEV-50 called naturally, the DEV-30.
-> No longer looking for Hi-Vision LDs <-
(I buried that format finally)
www.ispeedonthe405.com
Jet-X is offline
post #4 of 9 Old 07-09-2014, 07:36 AM - Thread Starter
tomtastic's Avatar
Quoted: 866 Post(s)
Liked: 305
Thanks for the update, I thought 60p setting was odd for 3D. I just took a look at the manual, it's 60p for PS mode only, which must just be for 2D.
post #5 of 9 Old 07-09-2014, 11:56 AM
Predator - Brian
Jet-X's Avatar
Quoted: 18 Post(s)
Correct - 60p is for 2D only. I wish it did 1080/60p!
Jet-X is offline
post #6 of 9 Old 12-17-2014, 10:30 AM
Predator - Brian
Jet-X's Avatar
Quoted: 18 Post(s)
Just got an HDR-TD10 yesterday to compliment the DEV-3, and while I thought the DEV-3/5 was just an TD10 in binocular form (and generally still is), the IO distance of the DEV-3/5 is just a little bit wider than the TD10.
I also noticed the IO distance on the newer DEV-30/50 is considerably wider than the TD-10/DEV-3/5.
So for Sony IO distance, from narrow to widest, it appears TD-20/30 -> TD-10 -> DEV-3/5 -> DEV-30/50.
FYI if anyone cares.
Jet-X is offline
post #7 of 9 Old 12-17-2014, 10:40 AM - Thread Starter
tomtastic's Avatar
Quoted: 866 Post(s)
Liked: 305
Interesting, and have you noticed any difference with the 1/3" sensor compared to the 1/4"? How's the extra zoom range?
With the main feature being that these are binoculars, with distance shots being their main use, I would think they'd have much wider lens spacing, but no.
This line intentionally left blank.
post #8 of 9 Old 12-17-2014, 11:07 AM
Predator - Brian
Jet-X's Avatar
Quoted: 18 Post(s)
I only have the DEV-3 and the TD-10 which use the same 1/4 sensors. Also I just got the TD-10 last night so haven't had time to play with it and compare to the DEV-3.
And as you pointed out, the DEV-3 doesn't have enough spacing to get good 3D at distance. I took the DEV-3 after just getting it onto a project, and while the close distance 3D was great (especially in the cockpit), the long distance shots were rather flat.
In the trailer below, the exterior landing/take-off shots were shot with the DEV-3 and in post, they're fairly flat. It would have certainly benefited from an SBE. It doesn't help that there's not a lot of objects near a runway to use in the foreground to give depth to the shot.
I'll have to compare zoom ratios because in 3D, the DEV-3 has a 5x zoom, whereas the TD-10 has a 10x zoom.
I'm going to acquire a DEV-50 in the near future, and likely (pending further projects) a TD20/30.
Jet-X is offline
post #9 of 9 Old 12-17-2014, 09:46 PM - Thread Starter
tomtastic's Avatar
Quoted: 866 Post(s)
Liked: 305
Oh, sorry. I thought you said Dev 50, I see you said TD 10.
Reply 3D Source Components
