Optoma 3d Projector - AVS Forum | Home Theater Discussions And Reviews
Old 08-30-2014, 07:22 PM - Thread Starter
Liked: 0
Optoma 3d Projector
Hi there Im new to the forum so please forgive me if I post in the wrong section.
Anyway my problem is as follows, I just bought a projector Optoma HD25e which includes full 3d , now the 3d works based on a optoma bc100b 3d rf emmiter, my question is, can i use my laptop to watch 3d movies on the projector and if yes, how would I do this.
Thanks in advance
ciprian9 is offline
Old 09-02-2014, 11:34 AM
3DBob's Avatar
Quoted: 358 Post(s)
Liked: 115
It should/could work using PowerDVD14 or Arcsoft Total Media Theater software. Use the trial versions to test it out. You will need a bluray player on your laptop and it should be the latest quad cpu and graphics cards, though. Also need a good 3D capable hdmi cable. You should be able to show MPO, AVCHD files and 3D bluray discs. You might check out the Under $3000 Projector forum. They do have a thread there for your projector. Or you can ask a generic question regarding use of laptops to projectors as well. Good luck.
3DBob is offline
