Last week, I updated from PDVD14 to PDVD15 Ultra. I've now had a chance to mess with it a bit with 3D content. At this point, I'd say, if you already have PDVD14 and use it for watching 3D, don't bother updating unless you really want direct BD iso file play.
It appears to me that, at least with regard to 3D, this program is a GIANT step backwards. Forinstance, it will no longer play files that are 1080 sbs half frame in 3D. Today, I also discovered that it also will no longer play in 3D 720 60p files that have been rendered in its sister program, Power Director. For some reason, it will play in 3D 720p files that were rendered in Edius. As for its ability to play 3D iso files, that seems to be OK.
So, if you already have an earlier version of PDVD, and it's meeting your 3D needs, you may want to pass on this one or try it on a trial basis if possible to see if you like it. I've left PDVD14 installed on my computer and will continue to use that one for 3D. If you want it mainly for directly playing iso files, then it may be helpful for that purpose,
1ST Edit: I originally said that it wasn't playing 3D iso files correctly on my projector/HTPC. I now have solved this issue and it does seem to be playing these files well.
2nd Edit: It will play SBS but the interface is bizzarre. You first must start playing the file, then pause it. Then you right click over the playing area and a menu will pop up which will have a SBS option. Once set, it will play the SBS correctly. If you close the program, the next time you want to play an SBS file, you will have to do this setting again.
