Viewing 3D MKV in Windows 7 ? HELP! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-03-2016, 11:42 PM - Thread Starter
Liked: 0
I have a Windows 7 based HTPC with an Intel HD2000 motherboard integrated graphics card, running Emby. I have a 3D capable Blu Ray player, and watch Blu Ray 3D movies using Power DVD 15. My HTPC is hooked to a 3D capable Samsung HDTV.
I've ripped 3D Blu Rays from my collection using MakeMKV's 3D MKV (MVC) option, but I am unable to play them in MPC-HC or any other program I've tried. The only luck I've had is with Stereoscopic Player, of which I only have the demo version. Stereoscopic player is somewhat expensive and would require me to manually activate 3D on the TV's remote every time I watch a movie. It also seems that you can't reconfigure the fast forward\rewind keyboard shortcuts, so its a bit incompatible with my current setup.
Does anyone know of another (preferrably freeware) 3D MKV player that is compatible with Windows 7? Is there any way to get 3D to work in MPC-HC or MPC-BE?
Mike
mranim8or is offline
post #2 of 2 Old 08-02-2017, 06:48 PM
ehb224's Avatar
Mike
Daum PotPlayer. It's free and works better than stereoscopic player or Bino. https://potplayer.daum.net/
VLC also plays 3D MKV files but not as well as potplayer.
ehb224 is offline
Reply 3D Source Components
3d htpc samsung mkv mvc
