Field Sequential (not frame sequential) 3D dvds - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-16-2017, 09:04 AM - Thread Starter
Liked: 0
Red face Field Sequential (not frame sequential) 3D dvds
I have an old 3D DVD "Encounter in the 3rd Dimension" made for IMAX presentation. I can project it in 3D by Color Code (anaglyph) but not field sequential (old CRT method). Is it possible to convert Field sequential to side by side 3D using Cyberlink Power Director or similar programme. I'm in the UK (pal system) but the projector - Panasonic PT AT 5000 can project NTSC as well. Sorry to appear so thick but when you get to 75 everything starts to fall apart.
Malamorphic is offline
post #2 of 3 Old 09-17-2017, 12:10 PM
tomtastic's Avatar
Quoted: 866 Post(s)
Liked: 306
Not in Power Director, it only accepts 2D, side by side, top/bottom and MVC. I checked Vegas Pro, it does have line alternate I believe that's odd/even rows, I don't think that's the same thing as field sequential though.
In Bino player there is alternating left/right mode which I believe is what you want. If you just want to play the DVD that might work. If you want to convert the file to another format, not sure. Might be another tool out there.
https://sourceforge.net/projects/bino3d/files/
This line intentionally left blank.
tomtastic is offline
post #3 of 3 Old 09-17-2017, 12:43 PM
3DBob's Avatar
Quoted: 476 Post(s)
Liked: 161
I have not tried this, but it might work for you: http://bino3d.org/ If you do try it, please let us know, thanks.
3DBob is offline
Reply 3D Source Components
