3D advice for new 3D capable video glasses - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-11-2010, 10:14 AM - Thread Starter
method0075's Avatar
Greetings everyone,
First off, I apologize if I am posting in the incorrect forum. I have purchased a set of VGA/composite video glasses that are 3D capable. I have inexperienced in the world of 3D and need some advice on this subject
It looks like I need a 3D capable video card for my computer. Beyond that, Do I need any software? and what video card does everyone recomend.
Is it possible to feed the computer an image/input source and then have the video card convert it to 3D to be displayed?
Thanks to anyone that may be able to help me getting started with this...
method0075 is offline
post #2 of 2 Old 02-26-2010, 08:16 AM
defiancecp's Avatar
Do the glasses have two video inputs? If so, your best option (IMO) would be to use the iz3d driver (available in demo mode for 30 days, something around $50 afterward) in "dual projectors" mode. I use that driver and the compatibility is excellent.
For video cards, the driver is compatible with any modern ati or nvidia card. I'm quite partial to the ATI Radeon 5750 for a good performance budget card, or one of the 58xx cards if you want to add in some more performance. The 5750 will struggle with the double-rendering of 3d at extreme resolution and detail levels, but most of the glasses are relatively low res by nature, so you have a bit of leeway there.
2d-to-3d conversion... well, there are a lot of systems that claim 2d-to-3d conversion. Even Iz3d is experimenting with it. Most of the results I've seen have not been pleasant, though.
defiancecp is offline
Reply 3D Tech Talk
