3D projector & xpand glasses - what next - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-02-2010, 04:21 PM - Thread Starter
jmal's Avatar
I've just got my hands on a 3D DLP projector and a pair of xpand glasses.
I have also downloaded a Stereoscopic Player and 3D content but I still cannot seem to get the image working correctly.
My laptop's graphics card outputs 120 hertz? What am I doing wrong?
Anyone any suggestions?
jmal is offline
post #2 of 2 Old 03-02-2010, 07:32 PM
taz291819's Avatar
First, you need to determine the resolution and refresh rate your projectors needs for 3D. Once you get that straightened out, you should be able to put the projector into 3D mode. With Stereoscopic Player, make sure you have the output method setting set for DLP, and the input (determined upon the media) set for it's correct method.
Currently testing 3D with Sammy DLP, shutter glasses, and HTPC
taz291819 is offline
Reply 3D Tech Talk
