3-d and xbox - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-05-2010, 12:13 AM - Thread Starter
Vader34's Avatar
Can anyone help me with this I know enough but on this I'm stumped.I want to hook my Xbox to my 3d enabled plasma from what I see I need to go like this xbox-cpu-tv.
Vader34 is offline
post #2 of 3 Old 03-05-2010, 07:04 AM
Waltm's Avatar
From what I understand, with the 3d ready dlp sets, if you are trying to hook up the xbox to a display that has the 3d sync port on the back you just use the hdmi cable from the xbox to the display. Then the emitter for the compatible glasses plugs in the back of the display (3d port). Your 3d ready game (Avatar) needs to be set to 3d mode and the display switched to 3d mode.
I'm not sure if this applies to your plasma though.
Waltm is offline
post #3 of 3 Old 03-08-2010, 12:12 AM
Anthony1's Avatar
Quoted: 588 Post(s)
Liked: 352
Anthony1 is offline
Reply 3D Tech Talk
