AVS Official Mitsubishi 3DC-1000 3D Starter Pack Topic! - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 2966 Old 07-10-2010, 04:07 PM
ajricaud's Avatar
Originally Posted by ChrisHawks View Post
I did , in fact, use the Samsung SSG-2100AB glasses with the Mits system, and they are identical and perform just as well as the stock Mits glasses. They are obviously from the same vendor, and for all intents and purposes, are the same glasses. Identical in every way.
--Chris
Chris, do you know if the Mits/Samsung glasses will fit over prescription glasses?
ajricaud is offline
post #62 of 2966 Old 07-10-2010, 05:22 PM
advocate2's Avatar
Originally Posted by mhetman View Post
There are some 3D Demo games you can download from the PS3 Store. Some require that you have a new 3D tv which it checks for. I could not try these out because my DLP 3D Ready TV was not detected by the PS3 and hence wouldn't run. Hopefully, the Mits converter will satisfy this check.
I have downloaded all the PS3 games for 3D and all except Pain worked perfectly with the Adapter. They even played fine when I ran the HDMi from the PS3 to my Yamaha 1.3 sound system and then to the adapter.
advocate2 is offline
post #63 of 2966 Old 07-10-2010, 06:37 PM
quickfire's Avatar
advocate.....are you saying PAIN did not work with adaptor?
quickfire is offline
post #64 of 2966 Old 07-10-2010, 08:14 PM - Thread Starter
ChrisHawks's Avatar
Yes, they easily fit over prescription glasses. I had a 3D viewing party last nite, and several people wore rx glasses. They remarked on how comfortable the 3D glasses were over their own.
ChrisHawks is offline
post #65 of 2966 Old 07-10-2010, 09:23 PM
bornagain1's Avatar
Chris, thanks for all of the great info. I have a Mits 3D starter kit coming in on 7/14. I need at least four more pairs of glasses to supplement the two that come with the kit. What is the most economical way to go?
bornagain1 is offline
post #66 of 2966 Old 07-10-2010, 09:25 PM
nc88keyz's Avatar
Quoted: 154 Post(s)
Liked: 78
e_b_aY
HT1: UN78JS9500, AVR: AVRX-7200WA, AMP: UPA-7, SPKRS: L/R: Veritas 2.3I C: 2.0CI SUR: V2.0R,, SUB: SVS SB13Ultra x2 ATMOS: 4X RC-6C, NUC i5/KODI, ChromeBox/KODI, ShieldTV
HT2: LC80LE844U, AVR: AVR4311CI, SPKRS: L/C/R: Veritas 2.2C, SUR: RC-RCRx2, SUB: 10.3x2
STORAGE: DS1812, DX513 x 2 - 4TBx18 Hybrid Raid, (It Just Works!!) R/C: HarmonyOneX2, Harmony880x1
nc88keyz is offline
post #67 of 2966 Old 07-10-2010, 09:40 PM
ajricaud's Avatar
Many thanks!
ajricaud is offline
post #68 of 2966 Old 07-10-2010, 09:53 PM
RigorousXChris's Avatar
Quoted: 127 Post(s)
Liked: 37
Where's the best place to purchase these right now? I'm waiting for Frys to have them just in case I want to return them or if they are defective.
JVC RS500 | Pioneer SC-95 | Panamax M5300-PM | BDI Marina
Klipsch RP-280FA | RP-450CA | RP-260F | RP-250S | RP-140SA | SVS PSB-12 NSD
4k MadVR HTPC | Panasonic DMP-UB900 | PS4 Pro | Roku Ultra | DirecTV Genie
RigorousXChris is online now
post #69 of 2966 Old 07-10-2010, 11:20 PM
Hyabusha's Avatar
Quoted: 67 Post(s)
Liked: 50
Yes! The user's guide shows using a HDMI 1.3 receiver as a switching source. So that is what Mits is recommending to use multiple 3D sources with it.
Oh hell yeah! Perfect! ^_^
Video Games, and Home Theater Forever! ^_^
My Theater Video-https://youtu.be/GdpdQgCSdW0
Hyabusha is offline
post #70 of 2966 Old 07-11-2010, 12:10 AM
curtishd's Avatar
Quoted: 152 Post(s)
What's on the Disney 3D bluray?
curtishd is online now
post #71 of 2966 Old 07-11-2010, 12:53 AM
curtishd's Avatar
Quoted: 152 Post(s)
I'm interested to see if you hooked the adapter and emitter up to a different HDTV if it would also be able to project a 3D image?
post #72 of 2966 Old 07-11-2010, 01:55 AM
advocate2's Avatar
Buy the Samsung starter pack for 185, sell the 3D Bluray for 60 bucks, gets you the glasses for $60 each.
post #73 of 2966 Old 07-11-2010, 04:38 AM - Thread Starter
ChrisHawks's Avatar
I'll try to post a review of the Disney Bluray sampler today.
post #74 of 2966 Old 07-11-2010, 04:44 AM
Athlon646464's Avatar
The purpose of the adapter is to convert non-checkerboard 3D signals to checkerboard so that Mitsubishi DLP's (2007 thru 2009 models) can display 3D.
It will not enable 3D on a non-Mitsubishi 3D capable TV, or any other TV for that matter. (It will only work for Mitsubishi '3D ready' TV's.)
Dave
Uxbridge, MA.
Athlon646464 is offline
post #75 of 2966 Old 07-11-2010, 05:41 AM
advocate2's Avatar
I played with the game Pain a little more and realized that the game is not entirely in 3D. I was playing a part not in 3D. Once I corrected the error of my ways I was able to play those sections available as 3D fine. I'm sorry for my earlier post where I didn't get it right.
post #76 of 2966 Old 07-11-2010, 05:44 AM
advocate2's Avatar
I don't have a 3D bluray player so I can't do the review. The entire disk is only 22 minutes long. It has trailers of a variety of Disney movies.
post #77 of 2966 Old 07-11-2010, 11:29 AM
bt2184's Avatar
The Samsung SSG-2100AB are identical to the glasses shipped with the starter kit and work perfectly with it. You can buy these on Amazon for around $120 to $130 each.
Otherwise you would have to buy the D-Link glasses and it seems like some people have had trouble using D-Link with the IR Emitter glasses at the same time.
bt2184 is offline
post #78 of 2966 Old 07-11-2010, 11:52 AM
walford's Avatar
I have not seen any reports from the 2 o3 3 users that got their starter kits in the last 2-3 days that they can not run the starter kit glases with the emitter and DLP-link glases at the same time.
walford is offline
post #79 of 2966 Old 07-11-2010, 01:04 PM
Augerhandle's Avatar
Quoted: 753 Post(s)
Liked: 651
You may have forgotten.
Originally Posted by advocate2 View Post
So there is a glitch. I had previously ordered a set of the Xpand 102's. I had noticed before that they work best with the 3D reversed in the Mits Menu. Although the Xpand work fine with the Directv broadcast in 3D and the reversed Mits output, the glasses in Kit work without the reversal. If I want to use all three sets of glasses, the Xpand's have to be worn upside down.
I am using the emitter for the Kit glasses....[snip]
Reversal is required when they are opening the content for the left eye when the contetent for the right eye are being displayed and vice-versa. It two differnt kinds of glases are not in sync with revesed or non reversed mode then you have a severe problem. I have not idea on how to solve the problem. Regrefully you decided to try and use them both at the same time.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #80 of 2966 Old 07-11-2010, 02:10 PM
Impala1ss's Avatar
Just got back from BestBuy where I watched a Samsung 3D tv w/ Samsung glasses. Watchd the World Cup final for about 10 minutes. This was my first time seeing 3D tv.
I was disappointed at the picture, frankly. While the 3 D effect was interesting, it was not what I thought it would be. The picture was slightly darker, as expected with the glasses, but my eyes bothered me after about 5 minutes. As the camera followed the play, the crowds in the background were slightly blurry, but not in the norman "blurry" way. It was almost as if my eyes were out of sync with each other; the ball was slightly blurry as it moved also. Overall the picture was sharp.
I simply didn't want to watch anymore even though I could have at the display with 2 soft chairs and just me watching.
I am a little bummed out now. I couldn't wait for the Mitu. adapter/glasses to come out but now I'm wondering if I want to spend $400 to see a picture which doesn't look as natural as my Mitsu.73837 HD.
Could it have been the Samsung TV? Or what do you think I experienced?
Impala1ss is offline
post #81 of 2966 Old 07-11-2010, 02:46 PM
DanielJoy's Avatar
anyone test this to see if it is compatible with 3d vision and HTPC?
We might have to wait for nvidia 3dtv play software. but it would be nice if the emitter was the same as nvidia's
Intel I7 920 overclocked 4ghz
Asus Rampage Extreme II
2 Ge-force 480 in SLI
295 PhysX Card
12gb 2000mhz ram
Intel SSD RAID
BR RW
1000w Sony
Mitsubishi 65" 3d HDTV
NVIDIA 3D Vision
DanielJoy is offline
post #82 of 2966 Old 07-11-2010, 03:00 PM
JamesN's Avatar
Can anyone confirm whether it includes Working for Peanuts?
JamesN is offline
post #83 of 2966 Old 07-11-2010, 03:45 PM
advocate2's Avatar
From the Back Cover of the Mits Demo Disk:
Shorts: Working for Peanuts and Timon and Rumba's 3D Experience
Trailers: Disney's a Christmas Carol, Alice in Wonderland, Toy Story 3
Clips: Disney's a Christmas Carol, G-Force, The Nightmare before Christmas
Mine is going up on Ebay once I take some Pictures.
post #84 of 2966 Old 07-11-2010, 04:18 PM
Quoted: 753 Post(s)
Liked: 651
James is happy now
post #85 of 2966 Old 07-11-2010, 04:19 PM - Thread Starter
ChrisHawks's Avatar
Originally Posted by Lee Stewart View Post
What Disney content is on the included 3D BD?
Here's a quick review of the included Disney 3D Showcase DVD:
The disc runs less that a half hour. The overall picture quality ranges from to good to excellent. Scenes of flat animated characters such as Timon and Pumba (Lion King), and Donald Duck are obviously not exceptionally 3D, although it looks decent. The disc really shines when it shows clips from 3D movies such as Christmas Carol.
Here's a rundown on the content:
Disc opens with Timon and Pumba explaining the wonders of the new 3D systems, especially the glasses. They tlak about how great the new 3D looks and you see a very quick teaser clip of Miley Cyrus in concert, which looks excellent.
Next they introduce a series of movie trailers, whcih are:
Christmas Carol: Outstanding 3D effects...looks great!!
Alice in Wonderland: I saw this at the theaters. Good movie, good actors, so-so 3D effect. But I will say it looks BETTER on my TV than it did on the movie theater. I wonder if they touched it up for Blu ray?
Toy Story 3; Haven't seen it yet...great trailer..great 3D!!
Next Timon and Pumba introduce several 3D film clips:
Christmas Carol: A scene with the ghost of Christmas past...best clip on the disc. Beautiful special effects..outstanding!
G-Force: I've never heard of this....a mixture of live action and talking animals (hamsters, etc.) Very funny...great effects!
Nightmare Before Christmas: I have to tell you, one of my favorite films anyway. It's been remastered in 3D...and it looks pretty darn good. I'm really looking forward to it's 3D release now!
And lastly, there is a funny Donald Duck animated film featuring Chip & Dale. Again, flat animation with a light 3D effect. Good 3d, not great. The kids will love this part. I thought it was cute.
So that's it!
post #86 of 2966 Old 07-11-2010, 04:39 PM
Hyabusha's Avatar
Quoted: 67 Post(s)
Liked: 50
Thanks for the review Chris H! Could you please take a pic of the front and back cover?
Hyabusha is offline
post #87 of 2966 Old 07-11-2010, 05:49 PM
JamesN's Avatar
Originally Posted by Augerhandle View Post
James is happy now
LOL!
Yeah...it's a personal favorite. I've seen it theatrically 4 times: 3 times in dual-35mm and once in Disney 3D (RealD).
If anyone wants to part with their demo disc, shoot me a PM.
JamesN is offline
post #88 of 2966 Old 07-11-2010, 06:46 PM - Thread Starter
ChrisHawks's Avatar
Here you go!
post #89 of 2966 Old 07-11-2010, 07:00 PM
Hyabusha's Avatar
Quoted: 67 Post(s)
Liked: 50
Here you go!
Thanks Chris! Every little Info helps the wait!
Hyabusha is offline
post #90 of 2966 Old 07-11-2010, 09:12 PM
Quoted: 1394 Post(s)
Liked: 589
Impala
Don't judge a technology from just one set.
If you're going to use the Mitsubishi system, then find a demo with their equipment.
JimP is offline
Reply 3D Tech Talk
