Xpand 102 and samsung a750 rainbows - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 07-11-2010, 06:42 AM - Thread Starter
destiny 21's Avatar
Quoted: 12 Post(s)
hi i have watches the panasonic demo disc on the panny 350 bluray player hooked to a 61 a750 dlp while wearind xpand 102 suaa glasses and on the left and right side of the dvd i can see purpleish streak halfway down the screen on both sides incredibly noticable when they show a sky scene also in the coral scene i can see severe ghosting around the fish. also havethe grand canyon adventure and the same thing with that one no ghosting just the purple streak on both sides when i take the glasses off sky if perfect blue color when i put them back on purple streks appear again. what do you think
destiny 21 is offline
post #2 of 18 Old 07-11-2010, 07:12 AM
buzzard767's Avatar
Quoted: 1618 Post(s)
Liked: 2393
Did you rename HDMI 3 "PC"?
Buzz
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #3 of 18 Old 07-11-2010, 07:15 AM - Thread Starter
destiny 21's Avatar
Quoted: 12 Post(s)
yes i did the 3d is great it is just those streaks on each side of the screen really annoying takes away from the 3d experience i think it has to be the glasses
post #4 of 18 Old 07-11-2010, 09:26 AM
buzzard767's Avatar
Liked: 2393
I'm not quite prepared to comment on this as I won't be receiving my BD 350 until tomorrow, but, I do have an HL67A750 and Xpand X102 glasses.
I put on a full screen white test pattern and there are rainbow colored vertical streaks a few inches wide on both sides of the screen.
Here's where it get weird - I pulled the battery out of the glasses and the effect was still there.
Here's where it gets more weird - I tried my Samsung side by side rechargeable glasses and got the rainbow colors with power on and faint shadowy streaks with the power off.
Tomorrow I'll see what effect, if any, the rainbow streaks have on normal programming.
Buzz
Buzz
post #5 of 18 Old 07-11-2010, 12:19 PM
walford's Avatar
If you turned theX102 glases off you were no longer properly receiving 3D content since the glases have to apply power to the inactive eys lens to make it as opaque as possible.
Have you tried turning down the brightness level on the TV?
walford is offline
post #6 of 18 Old 07-11-2010, 01:10 PM
buzzard767's Avatar
Liked: 2393
Buzz
I guess I should have elaborated. My comment about the 350 BD player arriving tomorrow was to indicate that I don't have any 3D content available today. What I observed was the glasses, both Xpands and Samsung SbS, creating images and color in 2D. Perhaps the cause is the Samsung DLP screen. I have no clue but hope that I do not see the same extra imaging while viewing normal 3D content, starting tomorrow.
Buzz
Buzz
post #7 of 18 Old 07-11-2010, 02:38 PM - Thread Starter
destiny 21's Avatar
Quoted: 12 Post(s)
what would turning down the brightness on the tv do. will it eliminate the streaks on the screen. then woudnt the 3d picture be darker and not have that pop to it
post #8 of 18 Old 07-11-2010, 04:53 PM
walford's Avatar
Turning down the brightness helps to insure that that that glases which do not turn 100% opaque for the inaactive eye are not subject to crosstalk from very light and bright scenes such as the bridge scene in the MvA BR disk. I do not know if it will have any effect on the purple lines.
Others with 3D DLP TVs have reported that turning down the brightnes greatly reuduced ghosting when playing 3D content.
walford is offline
post #9 of 18 Old 07-12-2010, 08:25 PM
buzzard767's Avatar
Liked: 2393
I'm now set up for 3D. There is some rainbowing. I just posted here.
It doesn't bother me a bit though but I can only speak for myself.
Buzz
Buzz
post #10 of 18 Old 07-13-2010, 06:02 AM - Thread Starter
destiny 21's Avatar
Quoted: 12 Post(s)
on my samsung 61 a750 with the 102 i see a light purple streak from the top to about halfway down the screen on both sides. i dont know if is the same thing you see because mine is not a rainbow like you see. also on the demo disc in the coral scene the fish sort of have a ring around them almost like double feature i wonder if you see that to. is this ghosting
post #11 of 18 Old 07-13-2010, 07:26 AM
mhetman's Avatar
I don't get any of these effects on my 67A750. I see no rainbows or ghosting whatsoever with my X102's. The demo disk plays perfectly through either my3D Plugin on the PC or through the Panasonic 350 player.
ASUS Formula III Rampage MB
Intel I7 960 CPU ATI 5850
12GB RAM 58TB Storage
Windows 7 Ultra 64 Bit
Arcsoft TMT5, Ceton Infinity4
Denon x7200WA to Samsung HL67A750
mhetman is offline
post #12 of 18 Old 07-13-2010, 07:37 AM
buzzard767's Avatar
Liked: 2393
Perhaps it's the screen itself then. The images on my A750 are immovable, fixed, only changing perceptible colors with a change in the background color and intensity, and the images are exactly the same with both pair of my X102's.
Buzz
Buzz
post #13 of 18 Old 07-13-2010, 08:22 AM
buzzard767's Avatar
Liked: 2393
No, I don't see anything like that. The only thing even close was when the fish with the black stripes pop out of the screen there "might" be a little bit of extra material over the dorsal fins but it is impossible to tell if this is extra content or the color of the fin itself. I put this scene in pause and took a hard look. Even if it is extra content, 1) I can't tell, and 2) it doesn't bother me one bit.
One odd thing about the demo disc, take the coral scene episode for example, is that in the opening scene where you look down at the water the waves are not moving. The background is a stationary picture. Also, in the Grand Canyon demo, in some scenes it looks like the far background is a painting. Weird, eh?
Buzz
Buzz
post #14 of 18 Old 07-13-2010, 08:34 AM - Thread Starter
destiny 21's Avatar
Quoted: 12 Post(s)
i dont see these purple streaks while watching regular bluray movies or tv but if i put the 102 glasses on the purple streak is there on the screen take them off streak gone. i sent my two pair back today. will be getting replacements in about a week or so
post #15 of 18 Old 07-13-2010, 09:15 AM
buzzard767's Avatar
Liked: 2393
I think you're going to be disappointed.
I just put a 100% white image that I use for calibration on full screen. My vision is 20/10.
1) No glasses - I cannot detect any excess images
2) Ordinary polarized sun glasses - I can just barely make out the images and suspect I could see more if the glasses weren't so dark
3) Samsung rechargeable SbS 3D glasses -
a) pwr off - very faint image
b) pwr on - image slightly more clear
4) Xpand 102 pair #1
b) pwr on - clearly visible image
5) Xpand 102 pair #2 - exactly the same as number 4 above
I am more or less convinced that the "problem" is the display panel itself but I must repeat myself and say that I am unbothered by what I see.
Buzz
Buzz
post #16 of 18 Old 07-13-2010, 09:36 AM
walford's Avatar
Certainly if your entire screen is the same color there can be no ghosting due to crosstalk since there are no images on the screen to ghost.
walford is offline
post #17 of 18 Old 07-13-2010, 09:45 AM
buzzard767's Avatar
Liked: 2393
This has nothing to do with ghosting or crosstalk. These are vertical streaks and mine are somewhat faintly rainbow colored.
Buzz
post #18 of 18 Old 07-13-2010, 12:12 PM
turls's Avatar
Quoted: 465 Post(s)
Liked: 194
I responded in the other thread. I have a HL61A750. Nvidia 3D Vision. I get the rainbows described. I have not tried to calibrate anything or change HTPC settings because everything else seems to be fine.
Matt
UMR on HDR vs 4K: The benefit of greater saturation and luminance capability is...not very evident in all images unlike more pixels which can be seen in every scene.
turls is offline
Reply 3D Tech Talk
