cleaning 3d glasses - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-09-2010, 11:45 PM - Thread Starter
steelers1's Avatar
Quoted: 92 Post(s)
i read a lot of posts here but never here much on cleaning these 3d glasses. what do you recommend to use to clean these glasses. i no that xpand has them. but a little expensive. any information please have a nice day
steelers1 is offline
post #2 of 8 Old 08-10-2010, 12:34 PM
peter0328's Avatar
Quoted: 48 Post(s)
If it's just smudges or fingerprints use a dry microfiber cloth.
If there is like candy stuck to them or something then take a slightly (barely wet) paper towel to try and get it off.
peter0328 is offline
post #3 of 8 Old 08-10-2010, 01:12 PM
GregLee's Avatar
Quoted: 801 Post(s)
Liked: 259
Don't press on both front and back of the glasses with a paper or cloth simultaneously. My shutter glasses come with a warning about that.
Greg Lee
GregLee is offline
post #4 of 8 Old 08-10-2010, 01:14 PM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
Microfiber cloth, do not use chemicals, and remember to not wipe both sides of one lens at the same time since too much pressure can damage the liquid crystal layer.
Jason
Media Room = Vizio 4K 70" lcd/Denon x4100/Audiosource Amp 100/Klipsch speakers/Velodyne subs/Sony BDP s780/PS4 Pro/X1S/WiiU/PS3/360/Wii/Game PC/Multi-Arcade / #standwithscotty / My HT SLIDESHOW
DaGamePimp is offline
post #5 of 8 Old 08-10-2010, 02:51 PM - Thread Starter
steelers1's Avatar
Quoted: 92 Post(s)
thanks for the help. great information there.
post #6 of 8 Old 08-10-2010, 05:36 PM
FBlack's Avatar
The Samsung web site has some info on cleaning the glasses.
http://ars.samsung.com/customer/usa/...&PROD_SUB_ID=0
FBlack is offline
post #7 of 8 Old 03-02-2013, 08:28 PM
Chip Buckman's Avatar
My PS3 3d glasses came in a soft pouch - the pouch doubles as a microfiber cleaning towlette. Oakley does this too with their sunglasses.
Chip Buckman is offline
post #8 of 8 Old 05-30-2013, 09:52 AM
gregalinnn's Avatar
The best way to clean your glasses is taking a Little of cotton wool or cotton wool ball preferably medical use to prevent dirt or trash in the same.
Always! clean softly one side of the lens at a time to prvent damage to lcd. If the glasses are very dirty or have grease that this is very common perform the same procedure but adding a few drops of water and dry it with a new cotton. Never use cotton which you used to clean other lens. I hope you serve. This works for me great!
gregalinnn is offline
Reply 3D Tech Talk
