Mits 73838 and fullhd - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-24-2010, 03:49 PM - Thread Starter
destiny 21's Avatar
Quoted: 12 Post(s)
hi i have a panasonic 3d bluray player bt350 connected to the mits adapter then to my mits 73838 dlp tv, can i watch 3d bluray movies in full hd with this setup or do i have to use checkerboard mode
destiny 21 is offline
post #2 of 4 Old 09-24-2010, 05:20 PM
gtgray's Avatar
Quoted: 207 Post(s)
Liked: 136
regardless of how you sent the stream to the TV, internally it will always be checkerboard. That is how 3d on DLP TVs work. So if you set the player to send full 3d you would need the Mits adapter to make it checkerboard. Might as well not have the adapter in line unless you need to convert a stream from another device that does not know how to output in checkerboard.
Samsung 78" JS8600, Mits WD-92840 43" Samsung 43ku7000 - Lumagen Radiance XS, Martin Logan Motion 40s, Ascend Sierra 2s
58" Panny Plasma -DVDO DUO, Usher S520, JBL HLS-610, Definitive SM45, MusicHall Marimba
gtgray is offline
post #3 of 4 Old 09-24-2010, 05:30 PM
JackBarry's Avatar
I believe the Panasonic Blu-ray player has the option to send checkerboard so you don't need the Mitsu adaptor.
JackBarry is offline
post #4 of 4 Old 09-24-2010, 08:01 PM
thepark's Avatar
Yes, the 350 has a checkerboard option. The adapter is not needed, but it is needed if you want to use Direc TV 3D for the set.
thepark is offline
Reply 3D Tech Talk
