Subtitles For 3D movies ? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 34 Old 07-13-2012, 11:27 PM
fits79's Avatar
Quoted: 46 Post(s)
Is there any easy program that create 3d subtitles from simple srt files that samsung 3d tv's support.
Already try the 3dsubtitler and i was try both idx/sub or sup internal or external on 3d mkv files but neither of these it works.
It worked ONLY with external media player product NOT WITH SAMSUNG INTERNAL MEDIA PLAYER WHY IS THAT HAPPENING?
fits79 is offline
post #32 of 34 Old 08-16-2012, 10:28 AM
calcujet's Avatar
Please try GOM player
You may search it from google and it is free
calcujet is offline
post #33 of 34 Old 08-16-2012, 12:25 PM
fits79's Avatar
Quoted: 46 Post(s)
ONE MORE TIME....
I DON'T WANT PLAYER but program that can convert the simple srt subtitle file into 3d subtitles files the gom player you suggest me IT DOESN'T DO THE WORK i want so is useless...
fits79 is offline
post #34 of 34 Old 04-23-2013, 11:20 AM
Carlos Martinez's Avatar
Quoted: 14 Post(s)
I have tried what you suggest, but the program doesn't recognize or accept the sub file I created with 3DSubtitler.
Also the file Tsmuxer creates is a TS file, not an MKV file. How will MKVMerge accept that?
Carlos Martinez is offline
Reply 3D Tech Talk
