Can xbox kinect record 3d video - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-23-2010, 12:41 AM - Thread Starter
Aj5000's Avatar
Hy, I saw a hacked kinect rendering a 3d of a man at desk. Does this mean we can sat art recording 3d video with a kinect program.... We should be, right? 3d input = 3d output.
Aj5000 is offline
post #2 of 2 Old 12-24-2010, 01:51 PM
BioSehnsucht's Avatar
Not exactly. You can use the depth and color cameras to generate a colorized depth field, or with two or more cameras correlate several angles to get actual 3D modeling rather than just a depth field along a single axis (if you rotated the view of the depth field there would just be an empty space behind).
With two or more cameras you can take the data into some kind of rendering system and spit out stereoscopic imagery from more or less any angle though. Not a plug and play, get it and do it yourself sort of solution though.
BioSehnsucht is offline
Reply 3D Tech Talk
