Official Monster Vision Max 3D Thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 1080 Old 04-08-2012, 03:50 PM
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
Originally Posted by zeedub View Post
Is the 3dfury still outputting a 3d image on the screen. I am using the monstervision with curtpalme firmware on the 3dfury with great results.
I think so, that was my plan to but I updated the emitter while it was connected to the fury via the sync cable. Since then not one of my emitters will connect
I ran out of time but will try latter.
trans_lux is offline
post #632 of 1080 Old 04-08-2012, 07:38 PM
HokeySmoke's Avatar
The glasses may need to be paired again with the emitter. Have you done a factory reset of the glasses?
HokeySmoke is offline
post #633 of 1080 Old 04-08-2012, 08:43 PM
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
I can't get the emitters to sync up to the fury, the red lights just keep scanning back and fourth.
I'm sure something happened to the fury when I updated the emitter as it was attached via the sync cable. It also shows up as a device in device manager.
Anyone have the 3d fury firmware they could send me?
I can't get the fury guys to give it.
post #634 of 1080 Old 04-08-2012, 08:53 PM
saltysteven's Avatar
How do these glasses compare to the 3active?
Or the newer Panasonic??
saltysteven is offline
post #635 of 1080 Old 04-09-2012, 08:42 AM
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
From what I see both are specific to particular manufactures displays.
The monsters combo-glasses & emitter-are a really nice combo. Lots of adjustments in the emitter. This is the key element for me. All the other systems I have used that are IR relied on settings in the displays. I'm using them with a 3dfury and a display that is not natively 3D ready and thus has no adjustments.
Now if I can just get my 3dfury to work again...
post #636 of 1080 Old 04-09-2012, 09:09 AM
zeedub's Avatar
Have you posted in the hdfury forum. They seem pretty quick to respond and help over there.
zeedub is offline
post #637 of 1080 Old 04-09-2012, 09:19 AM
Does the emitter come with the monster vision glasses through Amazon for $72???
post #638 of 1080 Old 04-09-2012, 10:43 AM - Thread Starter
Vampyro's Avatar
Yes it does. I just got a second pair. Great value!
Vampyro is offline
post #639 of 1080 Old 04-09-2012, 10:53 AM
Great thanks!! Just ordered two!
What should I know before hand.?
Do they have to be tuned and is it difficult?
post #640 of 1080 Old 04-09-2012, 06:34 PM
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
Yes still no resolution. Waiting on firmware to try a reload.
I think the bottom line is don't update your emitter firmware while the sync cable is attached.
post #641 of 1080 Old 04-09-2012, 08:33 PM
adidino's Avatar
Quoted: 304 Post(s)
Liked: 237
So one of my Optima glasses will not sync up. The other pair of Optima and Monster glasss sync up fine. These used to work fine as well. Any ideas?
adidino is offline
post #642 of 1080 Old 04-10-2012, 07:39 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
Try to recharge the Optima glasses and do a reset. Information is in the instruction manual.
rwestley is offline
post #643 of 1080 Old 04-10-2012, 08:24 AM
adidino's Avatar
Quoted: 304 Post(s)
Liked: 237
I've already tried resetting. I'm thinking maybe re-pairing the glasses to the transmitter? I'll give that a shot and see.
adidino is offline
post #644 of 1080 Old 04-13-2012, 04:34 AM
DaveN's Avatar
Quoted: 66 Post(s)
With a Sony front projector VPL-VW1000 I can't get the Monster glasses to work. They keep searching for the 3d IR signal. My sony glasses work fine. I have tried placing the monster ir receiver facing screen, PJ, etc. w/o results. Do they work w/o the optional Sony IR extender-transmitter? Do I have a defective pair or is there some trick to getting them to sync?
Dave
DaveN is offline
post #645 of 1080 Old 04-13-2012, 07:18 AM
LVS
LVS's Avatar
^ How far apart is the Sony IR Emitter and where is it located? Make sure the lights are off when you try it because lights in the room interfere.
LVS is offline
post #646 of 1080 Old 04-13-2012, 07:42 AM
DaveN's Avatar
Quoted: 66 Post(s)
I've tried hanging the IR receiver on the PJ so it is inches and aklso facing it towards the screen but lights were on very low. I can try again with all lights off tonight.
DaveN is offline
post #647 of 1080 Old 04-14-2012, 04:17 AM
DaveN's Avatar
Quoted: 66 Post(s)
As usual, user error. I did not have the sensor cable pushed in quite far enough. All is well.
DaveN is offline
post #648 of 1080 Old 04-14-2012, 04:42 AM
adidino's Avatar
Quoted: 304 Post(s)
Liked: 237
awesome.
adidino is offline
post #649 of 1080 Old 04-17-2012, 11:53 AM
yesan's Avatar
Quoted: 18 Post(s)
So everything was working great I even was making progress on reducing flicker.
Then I decided to update to the Curt Palme listed firmware for the emitter to make polarity switching easier. Now the emitters will not sync with the 3Dfury.
I reverted firmware back to the Monster still no luck, took a new one and fresh cable out of the box and still no luck.
The only thing I can think of is that I did something to the 3DFury when I did the update as the emitter was connected to sync port. I can't imagine it back feed something but hey anything is possible.
Now all the emitters do is have the red LED's scanning back and forth.
No HUGO for the family on Easter
Any ideas?
What settings were you working with that helped reduce the flicker? I have an Infocus X10 running with the 3DFury, and I am about to work on reducing the flicker. Were you working with just the duty cycle settings or with delay as well? Please let me know. Thanks in advance.
yesan is offline
post #650 of 1080 Old 04-19-2012, 08:03 AM
trenchtownrock's Avatar
I have a Sony VW95ES. Are an emitter and the connection necessary? because VW95ES with Built-in Transmitter.
trenchtownrock is offline
post #651 of 1080 Old 04-19-2012, 08:29 AM
DaveN's Avatar
Quoted: 66 Post(s)
No.
DaveN is offline
post #652 of 1080 Old 04-19-2012, 08:36 AM
Do I only put on glasses?
post #653 of 1080 Old 04-19-2012, 08:50 AM
whitetrash66's Avatar
Quoted: 66 Post(s)
Liked: 42
I have 4 pairs of these for my sony projector. I find that they DO NOT hold a charge. If they are turned off for a couple of weeks, when i try to use them, they are dead even after a full charge! not just one, but all of them. I have tried using different chargers and everything but the battery life is awful. Am i the only one with this problem?
whitetrash66 is offline
post #654 of 1080 Old 04-19-2012, 09:53 AM - Thread Starter
Vampyro's Avatar
I think a couple of weeks with no power is reasonable. I noticed this also. The glasses will last a long time if used consistently. I would not worry about it
Vampyro is offline
post #655 of 1080 Old 04-21-2012, 08:10 PM
blueEyedFrog's Avatar
Hi All,
Here's an inexpensive solution for anyone experiencing reflection problems - Bat Vision!
http://www.avsforum.com/avs-vb/showt...1#post21935918
blueEyedFrog is offline
post #656 of 1080 Old 04-28-2012, 01:38 PM
The Knuckle's Avatar
So I have a Panasonic TC-P65ST30
Are the Monster Cable Glasses still the best glasses to buy for a Active shutter Plasma?
Are they still offering a better picture?
thanks for the help!
The Knuckle is offline
post #657 of 1080 Old 04-28-2012, 03:51 PM
eqzitara's Avatar
Quoted: 21 Post(s)
This won't work if I have an acer 5360 dlp projector and I want to use with 3d vision (I have 3d vision emitter) correct?
eqzitara is offline
post #658 of 1080 Old 04-28-2012, 06:54 PM
SpinsterSXRD's Avatar
Hi guys, before I jump into getting these glasses, and a 3dfury, can anyone tell me if there is any flicker at all? I am pairing it with an Epson 8350 pjay and it does 60hz. thanks for any replies
HT Set Up: Epson 8350 (soon upgrade to Epson Cinema 3000, Sony Strd G-920, JBL 7.1 Venue series speakers, JBL Sub12 subwoofer, Harmony One remote, Xbox/Xbox One, PS3/PS4, Panny DMP BDT330,
SpinsterSXRD is offline
post #659 of 1080 Old 04-29-2012, 09:10 PM
audionewer's Avatar
hi. u guys know how to reset / default the setting for the emitter. i want to reset the emittier to orginal setting. but i dont know how do i do that?
please help me.
i got hd33 projector.
audionewer is offline
post #660 of 1080 Old 04-29-2012, 11:52 PM
Robut's Avatar
please help me.
Read the manual http://www.monstercable.com/lit/Max_3D_manual.pdf
sec 2.1 Page 11 explains it.
Monster is selling the glasses and emitter for $59.95 now!!!!!
Robut is offline
Reply 3D Tech Talk
Monster Vision Max Active 3d Glasses
