Official Monster Vision Max 3D Thread - Page 23 - AVS Forum | Home Theater Discussions And Reviews
post #661 of 1080 Old 04-30-2012, 04:06 AM
G-Rex's Avatar
Quoted: 461 Post(s)
Liked: 289
With a Sony projector can 2 pairs of Sony glasses operate at the same time with 2 pairs of Monsters using the one Sony built in emitter Or does two emitters need to be used (the Sony and the Monster external). Thanks
G-Rex is offline
post #662 of 1080 Old 04-30-2012, 07:00 AM
LVS
LVS's Avatar
^ Yes, just one emitter. The emitter is outputting an IR signal so the Monster Receiver and the Sony Receiver in the glasses all operate fine, however, you must have the emitter from the Sony in front you firing back towards the glasses or they will not stay sync'd.
LVS is offline
post #663 of 1080 Old 04-30-2012, 04:55 PM
G-Rex's Avatar
Quoted: 461 Post(s)
Liked: 289
Thanks for the info. Will the built in Sony emitter not work even if the Sony 1000 is table top mounted a few feet behind me and just 10" over my head? If so what type of wire does the emitter require? I think I would need about 35' of wire.
G-Rex is offline
post #664 of 1080 Old 05-01-2012, 06:05 AM
LVS
LVS's Avatar
Ah, I was making an assumption on the Sony projector not having a built-in emitter and I read over that part in your post, sorry. You will probably be fine then. You may have to mount the IR-receiver from the Monster Visions near your projector but you will have to experiment. I would try the built-in emitter first for sure.
LVS is offline
post #665 of 1080 Old 05-01-2012, 07:33 AM
G-Rex's Avatar
Quoted: 461 Post(s)
Liked: 289
Ok, thanks. Hopefully I will have theater back up in 4 weeks. Then I will try that.
G-Rex is offline
post #666 of 1080 Old 05-02-2012, 05:52 AM
Wesley Hester's Avatar
Quoted: 54 Post(s)
Liked: 48
I got a pair yesterday for use with my Mitsubishi WD-92840.
The initial charge time was pretty much right at 3 hours as the manual stated it would be. I'm currently using the IR receiver cable and it works as advertised. The IR receiver itself isn't very sensitive however. My HDTV's IR blaster reaches over 12' but the Monster IR receiver can only "see" about a couple of feet at the most and doesn't have the range of my other IR 3D glasses' IR receivers.
When a 3D signal was detected for the very first time, the unit locked in immediately and the glasses synced as soon as I turned them on.
The image through the glasses looks great, there is less lose of apparent brightness, color shift at off angles is normal/minimal and there is no color banding with certain gradients like the less expensive 3Active/TrueDepth glasses I have tried. These glasses overall appear to have the same great quality as the Mitsubishi branded Xpand X103's I use.
I've really just wanted a pair of 3D glasses I could use exclusively for myself that were rechargeable and of good quality: I've finally found them.
Wesley Hester is offline
post #667 of 1080 Old 05-09-2012, 12:37 PM
Toknowshita's Avatar
Quoted: 37 Post(s)
Liked: 49
Just an update. These glasses are still available from Monster directly via their website. Considering the closeout price of $59.95 also includes the Tx with the IR receiver it is one of the better deals for active glasses. Also with the app the glasses are fairly tweakable. I am surprised they still have any in stock.
Toknowshita is offline
post #668 of 1080 Old 05-09-2012, 05:06 PM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
http://electronics.monstercable.com/...203d%20glasses
Order two pairs and use the following coupon to save even 10% more on these glasses with free shipping from Monster direct. This is a great buy.
MothersDay10Off2012N or the following code which is good at their outlet store until the end of the year.
news10off2011
I suggest that you update the firmware from the VIP site as soon as you get the glasses. This is the latest firmware and makes polarity adjustment easier. VIP (Bit Caldron) is the company that made the glasses for Monster. This firmware works fine with these glasses. The instruction manual on this site is also much better.
http://www.3d-vip.com/
rwestley is offline
post #669 of 1080 Old 05-09-2012, 06:32 PM
jasonmichaelh's Avatar
Quoted: 142 Post(s)
Liked: 58
Thanks for the code
Sony XBR-75Z9D | Oppo BDP-203 and 103D | UBD-K8500
Mirage OMD-28 (LR) | OMD-C2 (C) | OMD-5 (SS, FH, RH)
Yamaha CX-A5100 | NAD T973 x 2
SVS PB12Plus/2 | Dayton UM18-22 Sealed x2 w/ iNuke 6000DSP
Monster Power HTPS 2000
jasonmichaelh is offline
post #670 of 1080 Old 05-10-2012, 02:31 PM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
news10off2011
I had 2 pair sitting in the cart but couldn't bring myself to click the button since I'm still 6-8 months away from finishing my new theater. The 10% code pushed me over the edge and my order is in the books!
Thanks for the code(s)!
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
post #671 of 1080 Old 05-11-2012, 07:49 AM
derek's Avatar
Thanks for the code. Just ordered two pairs to add to my previous two pairs of the Optoma-branded versions. My GT750 came with transmitter but now have two spares plus the IR receivers which I may use in the future.
Derek
derek is offline
post #672 of 1080 Old 05-11-2012, 03:35 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Same here! Added two more pair...now I have 6 pair and all seating in my theater has a pair of glasses. Sweet!
Ronomy is offline
post #673 of 1080 Old 05-12-2012, 03:35 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
Glad that many of you have jumped on this great deal. I would suggest updating the firmware to the VIP version from Bit Caldron asap. This is the latest version and works with the Monster glasses.
http://www.curtpalme.com/forum/viewt...68a3ca0bb4bdfa
rwestley is offline
post #674 of 1080 Old 05-12-2012, 07:57 AM - Thread Starter
Vampyro's Avatar
Is there a reason to update besides the easier polarity switching? I haven't updated my glasses and managed to change polarity with a little effort seems like it would take more effort to update
Vampyro is offline
post #675 of 1080 Old 05-12-2012, 09:44 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
Update is very easy and you also get the ability to make adjustments with the firmware app. It only takes a few minutes for each pair.
rwestley is offline
post #676 of 1080 Old 05-12-2012, 10:47 AM - Thread Starter
Vampyro's Avatar
When you have Mac at home and PC only at work it becomes a chore. Ah well. Im still not totally convinced. Is there a noticeable difference?
Vampyro is offline
post #677 of 1080 Old 05-12-2012, 06:58 PM
Joseph MAK's Avatar
Thinking to get a 2nd pair of MV3D glasses. Is the xpand 103 the same as MV3D? Are MV3D and xpand 103 just different OEM?
Joseph MAK is offline
post #678 of 1080 Old 05-13-2012, 06:39 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
The Xpands are not made by Bit Caldron and are different from the MV3d glasses. The Xpands work with IR not RF.
rwestley is offline
post #679 of 1080 Old 05-13-2012, 09:04 AM
browerjs's Avatar
Quoted: 23 Post(s)
I finally broke down and picked up two pair of the mv3ds with the great sale. I'm assuming that I can just use a standard motorola smart phone usb plug to power the transmitter?
browerjs is offline
post #680 of 1080 Old 05-13-2012, 09:23 AM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
u
They should come with a cable. The glasses and emitter use the same cable that your cell phone uses and the Motorola charger works great with the glasses.
Ronomy is offline
post #681 of 1080 Old 05-13-2012, 11:57 AM
DaveN's Avatar
Quoted: 73 Post(s)
Originally Posted by Ronomy View Post
u
I could not get my new glasses to power up after charging overnight via a moto cell charger that was .75 Amp output. I also tried with a htc 1 amp charger and another model moto charger. I called Monster tech support support and they told me to hook them up to a computer usb port to charge that this was a known issue. That did the trick. They couldn't tell me why I was having problems with cell chargers.
DaveN is offline
post #682 of 1080 Old 05-13-2012, 01:44 PM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
It seems if that if you let the battery fully run down some external chargers will not work.
If you have an I-Pad or I-Phone charger I think they will work since they put out more power.
rwestley is offline
post #683 of 1080 Old 05-13-2012, 04:23 PM
SpinsterSXRD's Avatar
I went ahead and got 2 more pairs as well, now I will have 4 pairs. Can anyone please take me thru the process of upgrading the firmare? am I downloading the firmare, then plug the emmiter in my laptop/pc and run the utility program go to upgrade and run it? Does this in turn update emmiter and when I sync it up to the glasses does it send the upgrade to the glasses? Finally do I turn on the glasses one at a time or all 4 to sync them and upgrade them at once? Any input would be very grateful.
HT Set Up: Epson 8350 (soon upgrade to Epson Cinema 3000, Sony Strd G-920, JBL 7.1 Venue series speakers, JBL Sub12 subwoofer, Harmony One remote, Xbox/Xbox One, PS3/PS4, Panny DMP BDT330,
SpinsterSXRD is offline
post #684 of 1080 Old 05-14-2012, 04:33 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
Download the firmware updater from the like I posted above. Install the updater on your drive and plug in the glasses. Open the VIP upgrade Utility and hit the upgrade tab. Do the upgrade and follow instructions. It should take only a few minutes.
rwestley is offline
post #685 of 1080 Old 05-14-2012, 04:36 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
Turn the glasses on after the upgrade. The first time after the upgrade it may take a little longer because the new firmware is sent from the transmitter to the glasses. The glasses will sync automatically.
rwestley is offline
post #686 of 1080 Old 05-14-2012, 05:21 AM
browerjs's Avatar
Quoted: 23 Post(s)
Since I got two transmitter/glasses pair with the monster.com deal, I'm wondering how easy it is to setup a transmitter on two different displays (Sony Projector/Panny Plasma) and sync the glasses for that particular transmitter. Glasses would only be used with one display at a time.
browerjs is offline
post #687 of 1080 Old 05-14-2012, 07:00 AM
mrfattbill's Avatar
Quoted: 97 Post(s)
Liked: 89
Don't you mean the transmitter?
Bill
mrfattbill is offline
post #688 of 1080 Old 05-14-2012, 07:04 AM
Bill
yes, let me get this straight it's NOT the transmitter you update, only the glasses? OR both? I was under the impression it was the transmitter that gets updated and it sends the signal to the glasses
post #689 of 1080 Old 05-14-2012, 07:25 AM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
You only have to update the emitter with the VIP firmware. The glasses will update when they first link to the emitter.
Ronomy is offline
post #690 of 1080 Old 05-14-2012, 10:07 AM
SgtVideo's Avatar
Just to be clear there is no firmware sent to the glasses, it remains strictly in the transmitter. RF glasses are dumb receivers, whatever frequency that is sent to the glasses is how much they will shutter at within the adjustment range of the transmitter. Approximately 50-240 hz. The only smarts the glasses have are in the charging circuit and their binding to a particular transmitter.
SgtVideo is offline
Reply 3D Tech Talk
Monster Vision Max Active 3d Glasses
