Official Monster Vision Max 3D Thread - Page 28 - AVS Forum | Home Theater Discussions And Reviews
post #811 of 1080 Old 08-20-2012, 07:39 PM
Ewingr's Avatar
Quoted: 62 Post(s)
Cool. Thanks for that.
I just ordered a pair of Monstervisions. Goow ing to see how it goes. I may need to order the external emitter. Once I get something going, I'll order more glasses.
Ewingr is offline
post #812 of 1080 Old 08-20-2012, 09:47 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Didn't you order with the emitter? You'll need a charger too...use an old cell phone charger. They work fine for me!
Ronomy is offline
post #813 of 1080 Old 08-20-2012, 10:11 PM
Ewingr's Avatar
Quoted: 62 Post(s)
I ordered with the RF emitter, yes. But my unit is mounted in a soffit, and I'm not sure that the Monster RF unit will be able to pick up the IR signal. I'll mount it in the soffit too, but below the unit. I'm told the Ir for the 3d does not come out of the back IR port.
Ewingr is offline
post #814 of 1080 Old 08-21-2012, 07:53 AM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
I don't use the IR to RF converter. I just plug the RF emitter into the sync port. I don't use IR for 3D sync.
Ronomy is offline
post #815 of 1080 Old 08-21-2012, 03:22 PM
Ewingr's Avatar
Quoted: 62 Post(s)
I,m thinking you are using a different projector than I am. I have an Epson 5010e. I see no port called a "sync port". I do have an external 3D IR port, which is to use the 3D external IR emitter.
Ewingr is offline
post #816 of 1080 Old 08-21-2012, 05:03 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Right! You should be able to replace your IR emitter with the RF emitter. Unless you want to use both ir and ref glasses.
Ronomy is offline
post #817 of 1080 Old 08-21-2012, 06:41 PM
Ewingr's Avatar
Quoted: 62 Post(s)
So, it sounds like you are saying I can plug the Monstervision emitter into the external port for IR. I'll go over to the Epson Glasses thread and ask.
Ewingr is offline
post #818 of 1080 Old 08-21-2012, 07:01 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
If it has the standard mini din port, yes!
Ronomy is offline
post #819 of 1080 Old 08-21-2012, 07:12 PM
Ewingr's Avatar
Quoted: 62 Post(s)
No. It is an RF45, and I've read that to extend the IR emitter, you use Cat5 cable.
Ewingr is offline
post #820 of 1080 Old 08-21-2012, 07:15 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Doesn't look like it will work that way unless you can get a schematic of the output. It is an RJ45. So where is the internal emitter output on the projector?
Ronomy is offline
post #821 of 1080 Old 08-21-2012, 07:19 PM
Ewingr's Avatar
Quoted: 62 Post(s)
Its on the front. To the right of the lens, if looking at the lens. There'll be no room to put the the RF module in front if it, as it is in a soffit. (Working on ventilation now for cooling).
I'm going to initially try, and expect to fail, by putting the emitter under it, and maybe bouncing the signal, it will work. Otherwise, I need to get an Epson External emitter and hook to that port. Just another $80, but hope I don't need to spend it. rolleyes.gif
Ewingr is offline
post #822 of 1080 Old 08-21-2012, 07:33 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Always something in the way...its never always easy.
Good luck!
Ronomy is offline
post #823 of 1080 Old 08-21-2012, 09:43 PM
Ewingr's Avatar
Quoted: 62 Post(s)
Good luck!
Ain't that the truth?
I'll post how it goes.
Ewingr is offline
post #824 of 1080 Old 08-22-2012, 06:21 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Update 3: 10 days since I charged both glasses after the battery swap and both still showing a full charge!
Ronomy is offline
post #825 of 1080 Old 08-22-2012, 08:05 PM
Ewingr's Avatar
Quoted: 62 Post(s)
Those things seem determined to mess with you. But at least in a good way smile.gif
Ewingr is offline
post #826 of 1080 Old 08-25-2012, 08:29 AM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Update 4: finally the newer monster glasses are quickly flashing 6 times to the Optima 3 slow flashes. So the battery swap says the problem is the circuit board in the Monster glasses. I will bring both to work and try to figure out what is different.
Ronomy is offline
post #827 of 1080 Old 08-25-2012, 10:06 AM
Ewingr's Avatar
Quoted: 62 Post(s)
Good Luck. Let's see, how many days is that...and have you used the glasses?
Ewingr is offline
post #828 of 1080 Old 08-25-2012, 11:59 AM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Only powered on both pair to check battery levels. Its been 13 days.
I tried contacting Bit Cauldron and an auto response came to me from the VP of the company saying my response was received but he never replied back about where the wrong component is.
Ronomy is offline
post #829 of 1080 Old 08-25-2012, 02:24 PM
Ewingr's Avatar
Quoted: 62 Post(s)
Just got my first pair Monster's. I'm not sure they are working right.
I had a hard time getting them going, likely due to the learning curve. But I finally did. but here is what I experienced now:
Played the final bit of a movie (after not watching much while trying to get it working/synched, etc). So I wanted to start it over. I stopped the movie, red light on glasses started flashing. Restarted it, selected to play in 3D. Green lights on the controller are solid, and all lit. But the glasses just keeps flashing red, and not picking up.
Then after a while the light stopped. So I pressed the button and turned them back on, and they synched. Started watching movie, and in about 5 min, they started blinking again.
Any suggestions or thoughts?
Ewingr is offline
post #830 of 1080 Old 08-26-2012, 08:34 AM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Sounds like the IR is not being picked up to well from the projector.
Ronomy is offline
post #831 of 1080 Old 08-26-2012, 09:22 AM
Ewingr's Avatar
Quoted: 62 Post(s)
That isn't teh case. The device to pick it up is taped right to the front of the projector; all led indicators are green.
After posting above: the glasses went off, I turned them back on, and they stayed hooked up all the way through the movie. confused.gif
Ewingr is offline
post #832 of 1080 Old 08-26-2012, 09:49 AM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
I would move it around a little if it keeps happening. Could be some weird reflection interfering with it. Also keep the rf emitter away from the projector...maybe the projector is emitting EMI that is interfering. Just moving the rf emitter may solve the intermittent problem.
Ronomy is offline
post #833 of 1080 Old 08-26-2012, 10:01 AM
Ewingr's Avatar
Quoted: 62 Post(s)
Ok. If it continues, I'll try moving it. I put it on the projector with sticky tape because the instructions said that is thte best thing to do to maintain a solid connection.
Ewingr is offline
post #834 of 1080 Old 08-26-2012, 03:55 PM
mikemav's Avatar
Also the IR receiver plug is VERY hard to get fully seated in the RF receiver jack. Many have reported inserting it almost thinking they were going to break something for the force required. Be careful though, but check that to be sure it's fully in.
mikemav is offline
post #835 of 1080 Old 08-26-2012, 06:40 PM
Ewingr's Avatar
Quoted: 62 Post(s)
That is true. Seems like it doesn't belong in that port.
What I am finding is that if I change from watching a Blue Ray to Dish; there is several seconds of pause while it all switches over via the Onkyo receiver. During that few seconds, the glasses lose 3D connection (even if I have the projector to do 2D-3D conversion). They seem to not be able to re-establish connection until they go off. So, after 30 seconds or so the flashing stops, meaning the glasses are off, and I can turn them back on and it will hook up.
I am also finding the glasses difficult to even turn on. Seems as though I have to press the button a specific way. I've seen complaints about the button being hard to push. But I think you need to press in a specific area on the button. At least that is what it seems like. Sometimes I have to try multiple presses in different ways (ie different point of pressure; different length of press) before the come on. Based on the complaints I've seen, I am presuming this is pretty much normal for the Monsters.
I'm thinking I should look into some other brands. I like the RF though, so I guess that leaves VIP (hardly anybody sells these), and Optoma.
Ewingr is offline
post #836 of 1080 Old 08-28-2012, 05:50 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
I did try measuring components on the boards and the device I used did not point to any one component. The circuit itself changes the values too much to be able to find the exact component. I do see changes between the two. I would have to pull components off the cards and compare. I may still try a couple that I suspect might be at fault.
Ronomy is offline
post #837 of 1080 Old 08-28-2012, 07:22 PM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
There was mention of a resistor with the wrong value. Anything look like it might be the culprit?
Max
djbluemax1 is offline
post #838 of 1080 Old 08-28-2012, 07:38 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Max
That's what I originally heard too but then someone said it was a Cap. I see two caps that are a different color between the two boards. I have an auto measuring device that does resistance and capacitance. The numbers were different but different in a lot of places.
Next chance I have I will try pulling a couple resistors near what looks like the charging circuit or regulator. I emailed the VP of Bit Cauldron who I had spoken to in the past but he isn't responding to me.
Ronomy is offline
post #839 of 1080 Old 08-30-2012, 10:54 AM
SgtVideo's Avatar
When I spoke to the primary engineer at BC who was working on that issue back then, he reported there was an incorrect value resistor installed in the charging circuit. He doesn't answer his emails this year, so I assume he is no longer there.
SgtVideo is offline
post #840 of 1080 Old 08-30-2012, 01:22 PM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
BTW Ronomy,
Any photos of the innards of the glasses?
Max
Reply 3D Tech Talk
Monster Vision Max Active 3d Glasses
