Official Monster Vision Max 3D Thread - Page 36 - AVS Forum | Home Theater Discussions And Reviews
post #1051 of 1080 Old 05-10-2014, 07:08 AM
Witchboard's Avatar
Quoted: 108 Post(s)
Liked: 63
Originally Posted by Rolls-Royce View Post
Not really. There are some suggestions for different technologies (plasma, LCD, etc.), but not for specific models. Look for the online user's/setup guides at EStar America and 3D-VIP's websites. Some have settings for duty cycle and delay for different display types.
Thanks again. Very helpful stuff guys. I appreciate it.
Witchboard is offline
post #1052 of 1080 Old 06-28-2014, 06:07 PM
Drakul's Avatar
These glasses are starting to drive me crazy. They work nicely but anything that has to do with battery is inane.
It's such a pain to figure out how much battery is left and how they charge.
I plug them in to a usb wall unit, nothing blinks
I plug them in to my pc, nothing blinks
the manual says 'hold the button and release and you will get 2 long blinks for 50% battery, 6 mediums for 10% or 12 quick for close to dead"
I get 3 blinks.....
W... T... H....
Drakul is offline
post #1053 of 1080 Old 06-28-2014, 11:47 PM
Rolls-Royce's Avatar
Quoted: 239 Post(s)
Liked: 352
I get 3 blinks.....
W... T... H....
Which ones do you have? The latest ones have a red LED on the opposite temple from the charging connector that stays on until the glasses are charged, then it goes out. They will only do the rapid-flash charge indication of the blue LED next to the power switch when first turned on. The older models did a continuous slow dim-to-bright-and-back cycling of the red LED (called the "heartbeat") that indicated when they were fully charged.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #1054 of 1080 Old 06-29-2014, 08:59 AM
Drakul's Avatar
I have the old ones, bought them in Dec. 2012. I know about the heartbeat but they don't do that.
Incidentally I watched Lego Movie in 3D last night and it worked perfect but it's so frustrating not knowing how much battery I have and if it's going to die in the middle of a movie.
Drakul is offline
post #1055 of 1080 Old 06-30-2014, 12:08 AM
The Knuckle's Avatar
monster vision 3d glasses
I went to watch a 3d movie tonight and there was a horrible ghosting issue. I tried everything I could, I read the manual, tried to adjust the glasses with the joystick as instructed by the manual. When that did absolutely nothing I tried resetting the transmitter and glasses back to factory settings. It looks like the glasses reset but the transmitter does not. I then tried to download a firmware update with absolutely no luck.
I don't know what the hell happened, they used to work really good. Any help would be greatly appreciated.
The Knuckle is offline
post #1056 of 1080 Old 07-15-2014, 08:48 AM
spudz72's Avatar
BC300 Emitter and ZF2300GLASSES
Has anyone else noticed that Optoma now has a BC300 Emitter and ZF2300GLASSES? They note these are not compatible with the ZF2100 glasses. You would think with the new emitter starting with the letters BC it would be Bit Cauldron technology but it must not be? I wonder if they are now using Bluetooth instead? Anyone have an idea?
spudz72 is offline
post #1057 of 1080 Old 07-15-2014, 11:56 AM
Quoted: 239 Post(s)
Liked: 352
According to the Optoma website, the new glasses are capable of 96/100/120/144Hz (44/50/60/72Hz per eye). The older ones are only up to 120Hz. My guess is that they could have made them incompatible to avoid customer service issues due to the differences in supported refresh rates. Bit Cauldron may have also changed the frequencies their system operates on to avoid interference from everything else on the 2.4 gHz band.
...Royce...
post #1058 of 1080 Old 07-15-2014, 12:16 PM
spudz72's Avatar
According to the Optoma website, the new glasses are capable of 96/100/120/144Hz (44/50/60/72Hz per eye). The older ones are only up to 120Hz. My guess is that they made them incompatible to avoid customer service issues due to the differences in supported refresh rates. Bit Cauldron may have also changed the frequencies their system operates on to avoid interference from everything else on the 2.4 gHz band.
I'm not seeing that. According to the specs I found for the ZF2100 they also support 144hz.. See below..
ZF2100 Glasses Specification
Model Name/ Part No ZF2100 Glasses
Operating Frequencies 96/100/120/144Hz (44/50/60/72Hz per eye)
Operating Temperature 0'C - 40'C
Accessories Soft Carry Case, Cleaning Cloth, 2x Nose Piece, USB Charging cable
Dimensions 170 x 168 x 40 (mm)
Weight 39g
Battery Rechargeable Lithium Polymer - Up to 15 Hours use
Range Up to 40m (Dependent on environment)
Storage Conditions ≤90% Humidity
Display Requirements Projector / Display must have a “3D Sync” connector (VESA DIN3)
Source = http://www.optoma.co.uk/accessorydet...ZF2100+Glasses
spudz72 is offline
post #1059 of 1080 Old 07-15-2014, 12:28 PM
Quoted: 239 Post(s)
Liked: 352
Weight 39g
My bad. The Optoma US website doesn't have the supported frequencies for the ZF2100 glasses...
However, the datasheet for the ZF2100 on the US website doesn't list 144Hz:
http://optomausa.com/webresources/fi..._Datasheet.pdf
Looks like their different national websites aren't receiving the same info, or it isn't being updated in a timely manner.
...Royce...
post #1060 of 1080 Old 08-02-2014, 11:49 PM
JoeGrizzly's Avatar
Originally Posted by blipszyc View Post
Quote: Originally Posted by sjv
Is the latest firmware update for the Monster Vision Max 3D glasses V. 1.05.004 ? Thanks
This seems to be the latest. It updates your transmitter and glasses to the VIP version, which is the OEM software.
http://www.curtpalme.com/forum/viewtopic.php?t=27776
I haven't used my Monster 3D glasses in a year or so, now when I try to use them, they still work, but the picture is slightly out of focus. I don't have the same problem when using the glasses that came with my Optoma 3D-XL, so I'm just trying to figure out how to get the glasses back in focus. Does anybody have any quick tips on how I could do this? I tried holding the joystick on the transmitter to the left for 10 seconds to reset it, but it doesn't seem that does anything.
I downloaded this program and connected my transmitter via usb, but the transmitter just shows the red lights moving from side to side and the program says "Device Not Found" even after unplugging, restarting, etc.
JoeGrizzly is offline
post #1061 of 1080 Old 08-03-2014, 08:18 AM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
It might be that you have the polarity swapped. Flip the glasses upside down to verify. If so, I think with the latest firmware available, you can just hold the power button for 10-15 seconds to swap the polarity.
As for connecting to your PC, I found that I had to completely delete the USB item to get it to be re-recognized.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
post #1062 of 1080 Old 08-10-2014, 11:58 PM
JoeGrizzly's Avatar
Flipping them upside down doesn't seem to do anything. I held the power button down for 10-15 seconds and it caused the 3D effect to stop working and the light to flash red. When I hit the power button again to stop the light from flashing, the 3D effect comes back, but it's still out of focus.
It's very weird because the 3D is working, but the text is not in focus. I'm just testing on the TRON menu screen where it has the text and effects together. The text is even more out of focus when you take the glasses off, so they're clearly doing something, but aren't setup properly. I would be ready to question my eye sight, but like I mentioned before, the 3D glasses that came with the 3D-XL don't have the same issue and my eye sight is pretty solid.
Is there a way I can play around with the transmitter to try and adjust the settings? I read the instruction manual, but it's pretty confusing, and the transmitter is so minimal that it makes troubleshooting even more difficult when there's no clear notification of what you're doing on any sort of LED or on the screen.
post #1063 of 1080 Old 08-11-2014, 10:13 AM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
There is a little joystick on the transmitter that lets you change the settings. The 5 LEDs on the transmitter will get lighter and darker depending on the direction you use the joystick.
blipszyc is offline
post #1064 of 1080 Old 09-01-2014, 01:34 AM
JoeGrizzly's Avatar
Ok, but what directions should I push them in and what lights should I look for when trying to adjust for this issue? I tried reading the manual, but it's a bit tricky to know if you're in the correct settings and I'm not quite sure what settings I need to adjust to fix this issue.
post #1065 of 1080 Old 09-02-2014, 12:08 PM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
The lights on the transmitter will light up as you press one direction or the other. 1 light is lowest setting, 5 lights is highest setting. To be honest, I don't think you're going to be able to fix this problem. It sounds like something is wrong with either the transmitter or the glasses themselves and I don't think any of the settings will correct out of focus issues. I got so fed up with the batteries in the Monster glasses that I ended up going back to IR.
blipszyc is offline
post #1066 of 1080 Old 10-26-2014, 12:15 PM
horseflesh's Avatar
Quoted: 95 Post(s)
Liked: 47
Does anyone know if the Monster RF transmitter is compatible with XPAND RF glasses?
Earlier in the thread I saw that this was probably not true, but Monster has also changed the TX design since then, I think... If anyone can confirm compatibility either way I would appreciate it!
horseflesh is offline
post #1067 of 1080 Old 10-27-2014, 06:21 AM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
The Monster's are actually made by Bit Cauldron so any of the other BC glasses would work. Optoma made a set and Bit Cauldron themselves, but I think XPAND made their own glasses and transmitter, so I doubt it would work.,
blipszyc is offline
post #1068 of 1080 Old 10-27-2014, 08:57 AM
horseflesh's Avatar
Quoted: 95 Post(s)
Liked: 47
Got it, thanks!
post #1069 of 1080 Old 10-29-2014, 07:22 PM
Quoted: 239 Post(s)
Liked: 352
Not compatible. The BC (VIP, Optoma, Monster, and EStar) emitters and glasses use an RF system called Zigbee, and AFAIK, they are the only ones that do. All the other RF glasses are Bluetooth.
...Royce...
post #1070 of 1080 Old 10-29-2014, 07:26 PM
horseflesh's Avatar
Quoted: 95 Post(s)
Liked: 47
Thanks, appreciate it.
post #1071 of 1080 Old 12-19-2014, 06:01 PM
Liked: 0
Just got a couple of pairs of these in the hope they could resolve some ghosting issues on my Sony KD-65X9000B. Does anyone know how to get the IR sync to work? When you use the Sony glasses you have to "register" them with the TV, I'm wondering if this is why it won't sync. Any help would be much appreciated! Thanks.
Sirapples is offline
post #1072 of 1080 Old 12-20-2014, 04:55 AM
Liked: 0
Turns out that the Sony active 3D glasses use Bluetooth RF, hence why I can't sync the MonsterVisions as it's not an IR signal! Now, the tv doesn't have a 3-pin VESA input so I'm really left with only one possibility and that's there being a bluetooth adapter for the BC100 Emitter. Seems highly unlikely, but does anyone know or have another idea? thanks.
post #1073 of 1080 Old 12-21-2014, 06:22 PM
Liked: 0
Many thx for that info RR
aboveave is offline
post #1074 of 1080 Old 01-27-2015, 01:17 PM
jasonDono's Avatar
Will these work with Epsom 5030ub
I have 4 pairs of the monster glasses. I was hoping they would work with my new Epson. Any chance?
Jason
jasonDono is offline
post #1075 of 1080 Old 02-11-2015, 06:23 AM
derek's Avatar
Jason
Epson uses Bluetooth RF and the Monsters Zigbee so they are incompatible. Ping me if you end up selling your Monster glasses.
Derek
derek is offline
post #1076 of 1080 Old 09-16-2015, 04:34 PM
Liked: 0
Hi, I just bought 2 Max 3D glasses in hopes of reducing ghosting on my Samsung UN40FH6030. However, since I am unable to sync them up, I'm guessing my TV uses Bluetooth rather than IR sync (I haven't been able to find any info to confirm or deny this, but it seems the only logical explanation). I was wondering if there is any sort of converter for TVs that use Bluetooth sync that would make it compatible with the Max 3D? Thanks.
sennor is offline
post #1077 of 1080 Old 09-17-2015, 01:28 PM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
The glasses should've come with a cable that plugs into your TV that will take the 3D signal and convert it to the RF needed by the glasses. Perhaps your TV doesn't have this plug which means these will not work for you.
blipszyc is offline
post #1078 of 1080 Old 11-25-2015, 02:12 AM
Liked: 0
I think these glasses deserve their own thread...
Just hooked up my pair and I must say they not only are a lighter shade
but they add more pop to the 3D image.
I like how you can fine tune the image and essentially tune down ghosting as much as possible. I am using the glasses on a 63" Samsung Plasma from about 10 feet away and its obvious they work much better than the Samsung glasses that I received with MVA kit.
It seems like the samsung glasses were never really tuned into the signal as clearly as the monsters are. The 3d is much more in your face.
The major benefit from these glasses is that they never go out of sync! The samsung's would do this constantly and it drove me nuts. The tape cure never worked for me. Its nice to finally get the full 3D from this TV.
Please share your questions, opinions and reviews
Thomos is offline
post #1079 of 1080 Old 11-25-2015, 02:15 AM
Liked: 0
Thomos is offline
post #1080 of 1080 Old 01-11-2017, 10:25 AM
Alaric's Avatar
Hi There,
Just got a pair of these glasses second-hand. The origional Monsters and they work and hold charge!!!
I'm using a Mitsubishi HC9000 which I belive can be tricky to get good 3D on, but i'm working on it. Ocasionally in testing the image looks great, but then the scene changes and i get blurry bits. I love the fact that you can tweak the settings on these though that joystick, which is close to the projector and at distance from the screen means it's tricky.
I guess the way to do it is tweak the software settings, try, unplug, connect and tweak with the software again. Repeat until bored or a great picture?!?!?!
Interestingly the only source for the software i've found is an old VIP one off Curt's CRT site....the estar one is a dead link, Monster claim no knowledge and optima seem to want to flog you the 2300 version (is it a better system???)
BTW i've also tried
https://www.hi-shock.de/en/hi-shock-...system-2.4g-rf
Which do just work, but I think I pref the Monster glasses and hopefully can tweak to be better....Though thankfully came with the 5pin mini din cable to 3 pin Vesa mini din adaptor
Ta,
Lee
Lee Edward Armstrong
My Clothes Will Impress You, And My Claws Will Undress You. - The Damned
Alaric is offline
Reply 3D Tech Talk
Monster Vision Max Active 3d Glasses
