3D Displayer - VIP Product - AVS Forum | Home Theater Discussions And Reviews
post #1 of 701 Old 03-22-2011, 05:16 PM - Thread Starter
Billbofet's Avatar
Quoted: 53 Post(s)
Just wanted to start a thread for this specific VIP product.
I have seen a ton of information on the 3D Gamer and Theater product, but this is the unit I am most interested in.
If there is anyone out there that has received this unit yet, please post your impressions within this thread. Thought it would be a neater way to track the info vs. farming it out of the 3D Gamer thread.
Thanks in advance.
Billbofet is offline
post #2 of 701 Old 03-22-2011, 06:09 PM - Thread Starter
Billbofet's Avatar
Quoted: 53 Post(s)
Attached is a .pdf document I got from Jonathan regarding this product:
post #3 of 701 Old 03-22-2011, 07:21 PM
jadeezra's Avatar
This is the product I'm going with. At 299 I could care less if it doesnt work on direct tv. I'm in this thing for the blu ray's and video games. Its a steal imo.
jadeezra is offline
post #4 of 701 Old 03-22-2011, 08:36 PM
donyoop's Avatar
The question has been: what are they doing to support 60 Hz displays? The plot thickens... The pdf says 720 progressive output that is field interleaved??
Don
donyoop is offline
post #5 of 701 Old 03-22-2011, 09:50 PM - Thread Starter
Billbofet's Avatar
Quoted: 53 Post(s)
My understanding is that this product would basically work on all things PS3 - games, BD movies, Vudu, and PSN 3D rentals.
If that is the case, and others have good luck with the IR/emitter glasses, this one looks like a winner for me.
post #6 of 701 Old 03-23-2011, 02:11 AM
thebard's Avatar
Quoted: 86 Post(s)
Liked: 50
The Gamer does what you mention. This unit does blu-ray 3d as well.
A third unit, the Theater, handles cable/sat 3d.
Projectors: Where there's a wall, there's a way.
http://www.avsforum.com/forum/110-di...een-build.html
thebard is offline
post #7 of 701 Old 03-23-2011, 04:40 AM
Loppan's Avatar
Don
This is what I would like to know aswell, every time I see someone who ask about this there is no answer to it. Also, is it limited to 720p, I thought I heard 1080p from the beginning?
/Henrik
Loppan is offline
post #8 of 701 Old 03-23-2011, 08:50 AM
walford's Avatar
From the data sheet it appears that the unit will accept 1080p/24 frame packing 3D format from a 3D BR player or from a PS3 and can output it at either 720p/60 or 720p/120 using field interleaved format. It does not appear that the unit supports output using any 1080p 3D display formats. If using a standard 60Hz LCD or Plasma 2D TV I am not sure if using 720p/60 frame interleaved format will provide an acceptable 3D experience.
walford is offline
post #9 of 701 Old 03-23-2011, 08:55 AM
space123321's Avatar
I am confussed - what is field interleaved format? If this the old field sequential format? I have an hd66 and want to ensure that it will be the same experience as my 3dtv (frame by frame, not line by line...) thanks!
space123321 is offline
post #10 of 701 Old 03-23-2011, 11:51 AM
walford's Avatar
AFAIK Field Interleaved, Frame Sequential, Page Flipping, and possibly full SbS format and in some cases Over and Under format are all the same or very close to the same since they consist of sequential full frames alternating left an right eye content. None of thes format should be confused with the HDMI 1.4a 1080p packed double frame 3D format or the HDMI 1.4a 3D 1080i Side-by-Side 1/2 R format.
Maybe one of you who has used some or all of these formats can provide knowledge of whch of these are the same and/or which of these are certainly not the same.
walford is offline
post #11 of 701 Old 03-23-2011, 06:11 PM - Thread Starter
Billbofet's Avatar
Quoted: 53 Post(s)
Also wondering if this unit does SBS format and if the IR glasses with emitter are universal. Meaning, would any IR/emitter combo work?
post #12 of 701 Old 03-23-2011, 06:26 PM
perfectdark's Avatar
don't know about your emitter question. But the Displayer Does NOT do SBS
here is the low down
3D-Gamer --> 720p frame packed (a.k.a PS3 games and Hulu only)
3D-Displayer ---> 720p / 1080p frame packed (a.k.a bluray movies) and PS3 games
3D-Theatre ---> All files (SBS & TB) bluray movies, PS3 games, Xbox360 games, Sat/Cable .... (only thing it doesn't support is 1080p 60 @ SBS)
perfectdark is offline
post #13 of 701 Old 03-23-2011, 09:02 PM
cyclejim's Avatar
The gamer also does psn movies in 3d as well as vudu movies in 3d.
cyclejim is offline
post #14 of 701 Old 03-23-2011, 09:33 PM - Thread Starter
Billbofet's Avatar
Quoted: 53 Post(s)
The 3D Gamer requires a display with a 120mhz refresh rate. This is why I am honing in on the Displayer for my 60mhz projector.
post #15 of 701 Old 03-23-2011, 09:46 PM
cyclejim's Avatar
No problem, my intention was to correct the post above that did not indicate these capabilities on the gamer.
cyclejim is offline
post #16 of 701 Old 03-25-2011, 09:14 AM - Thread Starter
Billbofet's Avatar
Quoted: 53 Post(s)
Can't believe noone has received or chimed in on this unit yet.
This must be a little bit behind the Theater as far as shipment and release.
I am checking the threads hourly in hopes of getting some intel on this product!!!
post #17 of 701 Old 03-25-2011, 09:43 AM
hoogs's Avatar
Quoted: 24 Post(s)
First shipment of the Displayer is going out the first week of April.
hoogs is offline
post #18 of 701 Old 03-25-2011, 01:49 PM
Quoted: 17 Post(s)
I ordered mine on the 24th. It is now "awaiting shipment".Too bad it costs $335.95 US funds.... but maybe I can keep my Mitz hd1000 720P and NOT have to buy that Acer... as I'm drooling over my remotes.................... If it gives that FULL BLURAY 3D performance as what I read about.
Dickie
wanab is offline
post #19 of 701 Old 03-25-2011, 02:55 PM - Thread Starter
Billbofet's Avatar
Quoted: 53 Post(s)
wanab - really interested in your feedback. I have both a Mits HD1000 and HC3800 which are essentially the same save the resolution difference.
Curious to see how the glasses/emitter work for you. Keep me updated.
Bill
post #20 of 701 Old 03-25-2011, 06:17 PM
cybereality's Avatar
I call BS on this product. How is is supposed to convert regular 2D displays to 3D? Doesn't make any sense. And even if it does work, 30Hz per eye is garbage.
cybereality is offline
post #21 of 701 Old 03-25-2011, 07:33 PM
Quoted: 17 Post(s)
time will tell.....
Dickie
wanab is offline
post #22 of 701 Old 03-26-2011, 07:38 AM
threed123's Avatar
Liked: 39
VIP Displayer takes input from 3D bluray and PS3 and converts to 120hz frame sequential for 3D DLP ready projectors, and 60hz frame sequential (30 frames per eye) for non-3D projectors--but an IR emitter and corresponding 60-120hz capable glasses are necessary. Yes there might be slight flicker. According to other threads reviewing the VIP Theatre (which is a step up model to the Displayer), it works very well with minimum flicker and it's not as bad as you would think. We'll see.
threed123 is offline
post #23 of 701 Old 03-26-2011, 10:50 AM
defiancecp's Avatar
...30Hz per eye is garbage.
And you know this, having used some 30hz per eye product...? No? Oh. Ok then.
Maybe it won't work very well, maybe it will. So far feedback has been generally positive from the users that have tried it. We'll see in april when it gets more widespread distribution.
defiancecp is offline
post #24 of 701 Old 03-26-2011, 11:34 AM
12GAGE's Avatar
Quoted: 43 Post(s)
Liked: 37
Honestly, I think that most will be very surprised at how well 3D works at 60 HZ. While I am sure some people will be more effected by the flicker, my eyes adjusted in a matter of seconds. In addition, I think if VIP's product is compatible with the active glasses from Monster then the image quality can be further improved. It is just one of those things that you have the experience. Overall, I have been very pleased with the system; in fact it has been just as pleasing as my 3D experience with the Panasonic VT25 unit.
12GAGE is offline
post #25 of 701 Old 03-26-2011, 12:20 PM
jem454's Avatar
Actually Cyber knows 3d very well. Yes believe it or not many of us have used some 30hz per eye product. Shutterglasses have been around for many, many years. Now I wouldnt call 30hz per eye garbage at all, actually the 3d effect is very good, but it is harder on the eyes without a doubt.
jem454 is offline
post #26 of 701 Old 03-27-2011, 09:05 AM - Thread Starter
Billbofet's Avatar
Quoted: 53 Post(s)
Another question for the 3D experts out there.
My Mits HC3800 outputs 1080p/24fps at 48 frames per second.
Can I assume from this I would get true 1080p/24fps frame packed output displayed if I am using the Displayer and PS3 for 3D blu's? If so, would that take care of the "flicker" or help to reduce?
Thanks in advance,
Bill
post #27 of 701 Old 03-27-2011, 10:28 AM
defiancecp's Avatar
My apologies then. But he called the validity of his experience into question by calling it garbage in spite of many with the product reporting a reasonable experience, so it was not an unreasonable assumption that he had no such experience.
post #28 of 701 Old 03-27-2011, 10:54 AM
walford's Avatar
Thanks in advance,
Bill
I see nothing in the following specs for your PJ to indicate that it will handle 3D content or any 3D data format which are required to support DLP-Link and DLP-Link glasses.
http://www.mitsubishi-presentations....rs/HC3800.html
walford is offline
post #29 of 701 Old 03-27-2011, 11:42 AM - Thread Starter
Billbofet's Avatar
Quoted: 53 Post(s)
You are correct. That is why I am interested in this product. It has the ability to make non-3D displays output a 3D picture. I would also have to use the IR glasses/emitter as my pj does not have DLP link.
post #30 of 701 Old 03-27-2011, 01:20 PM
Chezbrgr2's Avatar
Brilliant post, its nice to know we won't be seeing you around these threads then. Go have fun with whatever works for you. I will be glad to use what I have, without having to be a computer genius to figure it out.
Wake me when HD gets Here!
Chezbrgr2 is offline
Reply 3D Tech Talk
