PC or 3DC-100s for my Samy DLP? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-01-2011, 09:49 PM - Thread Starter
Pain7's Avatar
Hi.
I have a Samsung 61" HL61A750..
My question is what is the difference between using a PC or the 3dc-100s? Is the 3D experience the same? I have a HTPC I use as it is. I'm wondering if I should get the 3dc-100s or just buy a Blu-Ray drive for my HTPC? I would only use the 3D for movies.
Thanks for any help..
Pain7 is offline
post #2 of 10 Old 06-02-2011, 10:15 PM - Thread Starter
Pain7's Avatar
I sure can use some advise..
Pain7 is offline
post #3 of 10 Old 06-03-2011, 12:32 PM
nickels55's Avatar
Liked: 36
I never went the PC route, so I went with the 3DA-1 adapter on my Sammy 6187s. Flashing the EDID is simple and the adapter alone only costs $100, well worth looking into that instead of getting that expensive 3DC-100s kit.
I can only give you my reasons:
With the adapter I could use the PS3. 3D movies are nice, but 3D gaming on the PS3 is incredible. I have comcast and TiVo HD, so I get a ton of 3D content on my set, but the adapter is necessary for the t/b or s-b-s formatted 3D content. My PC couldn't handle 3D output and its not close enough to my TV to be a decent option.
I imagine the 3D experience is the same, it is always based on the quality of the content. The PS3 plays 3D blu-rays as frame-sequential 1080p - it doesn't get any better than that. Comcast plays stuff SBS so the res is cut in half, result not so stellar.
If you only want to watch 3D movies then you are missing out on option #3 - the simplest and cheapest one: get a stand-alone blu-ray player that supports checkerboard output. There are a few brands that do this, then you don't need the 3dc-100s adapter. All you need is the player and a pair of ultra clear DLP Link glasses and you're all set.
http://www.amazon.com/Panasonic-DMP-...dp/B003ZXE87A/
nickels55 is offline
post #4 of 10 Old 06-03-2011, 02:03 PM - Thread Starter
Pain7's Avatar
Great thanks. Is there any other 3D blu-ray players that will work?
Also what glasses should I use for this TV?
Thanks again.
Pain7 is offline
post #5 of 10 Old 06-03-2011, 04:18 PM - Thread Starter
Pain7's Avatar
I ordered the Xpand X103
Pain7 is offline
post #6 of 10 Old 06-03-2011, 04:46 PM
Augerhandle's Avatar
Quoted: 747 Post(s)
Liked: 649
The X103s require an emitter! Best cancel and get the X102s.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #7 of 10 Old 06-03-2011, 05:33 PM - Thread Starter
Pain7's Avatar
To late man. I guess Ill have to return um..
I am really stumped on what blu-ray player to get.
What I need is one that will put out checkerboard and one that streams Netflix and DLNA. It has to play MKV, AVI, MP3's atlest. Seems all the Panasonics say they are DLNA but the reviews state they dont play AVI and mkv.
Pain7 is offline
post #8 of 10 Old 06-03-2011, 06:39 PM
Quoted: 747 Post(s)
Liked: 649
From http://www.xpand.me/products/universal-3d-glasses-x103/
Lens size2.2 diagonal (57mm)
3D Technology Active Shutter Glasses
Lens type LCD
Sync Method IR
From http://www.xpand.me/shop/dlp-link-gl...nk-3d-glasses/
DLP® Link Glasses (X102)
Glasses that utilize DLP®-Link communication without emitter
post #9 of 10 Old 06-04-2011, 07:57 AM - Thread Starter
Pain7's Avatar
Lens type LCD
Sync Method IR
Thanks bro.. I did get the order canceled..
Pain7 is offline
post #10 of 10 Old 06-04-2011, 10:50 AM
nickels55's Avatar
Liked: 36
For the money the Ultra Clear DLP Link glasses are superior to the Xpand ones.
Reply 3D Tech Talk
