Mits 3DA-1 stopped working on my Samsung - Page 9 - AVS Forum | Home Theater Discussions And Reviews
post #241 of 243 Old 12-06-2013, 01:25 PM
EmerJency's Avatar
Originally Posted by speedklz View Post
I just pluged this unit in and tried turning it on and the light on the front dosnt show.. Will this unit turn on if not hooked to a tv.. Just making sure it works, I bought it used and I am not home yet to test it.
I can verify that you need an incoming signal for it to power up. It will not show power without an input signal.
EJ
EmerJency is offline
post #242 of 243 Old 12-06-2013, 01:43 PM
Mounta1n's Avatar
Quoted: 52 Post(s)
Liked: 49
Needs to be plugged into the tv for it to light up I think. Not home to try, but that's what I recall.
Getting ready for the jump into full-on theater build
Mounta1n is offline
post #243 of 243 Old 01-02-2014, 11:18 PM
turls's Avatar
Quoted: 478 Post(s)
Liked: 206
This thread is awesome...I had the original Tru3D kit with the early date (I guess that company is long gone now), and didn't even have my Samsung 61" LED DLP hooked up for over a year. I did a big remodel, which included adding video matrixing. Of course I couldn't get anything to work with the Geffen piece. Once I found this thread and did the workaround, DirecTV and Roku 3D content work great.
What is the current verdict on DLP-Link glasses? Monoprice sells a set, and there are low cost options on Amazon. I have a set of Xpand and Optima but would like to add a few more.
Matt
turls is offline
Reply 3D Tech Talk
