LG 3D Smart TV keeps tripping out..... - AVS Forum | Home Theater Discussions And Reviews
Old 07-02-2011, 06:42 PM - Thread Starter
superstock's Avatar
Hi
We have just brought this TV. It keeps tripping out (turning itself off and on). We also have a LG Blu Ray Wireless Home Theater and Foxtel attached to it and it is all conected to a Monster Greenpower circuit board. The TV is the only thing that is tripping out not the Blu Ray or Foxtel.
Anyone help????
Thanks in advance
superstock is offline
Old 07-02-2011, 06:58 PM
Rolls-Royce's Avatar
Quoted: 244 Post(s)
Liked: 369
That kind of behavior isn't something you can change in the TV's settings. Try plugging it into a separate outlet and not the Monster power box. If the TV's power cycling continues, the set is probably faulty and needs to be exchanged. If the starting and shutting down stops, there could be an issue with the Monster power unit. I know you have other components on the power box, but they probably aren't drawing the same current as the TV. If the power output from the Monster unit is marginal, it could be causing the TV to cycle.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
