How do I play .iso 3D files on PowerDVD 11 or Arcsoft TotalMedia Theater 5 ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-22-2011, 12:05 AM - Thread Starter
Vancomycin's Avatar
I have the programs PowerDVD 11 and Arcsoft TotalMedia Theater 5 that can play 3D movies.
However, my 3D blu-ray movies are in .iso format.
How can I get PowerDVD 11 and Arcsoft TotalMedia Theater 5 to detect the .iso files so that I can play the 3D movies?
I am having trouble on how to get it to play .iso files.
Vancomycin is offline
post #2 of 8 Old 07-22-2011, 06:35 AM
nickels55's Avatar
Liked: 36
ISO files are disk images. You need to extract them with something like PowerIso or some other disk imaging tool. BTW - this is a not an expert opinion, so I could be 100% wrong.
nickels55 is offline
post #3 of 8 Old 07-22-2011, 02:57 PM - Thread Starter
Vancomycin's Avatar
So .iso files cannot be played? This is funny because I have spent so much time converting blue-ray folders to iso . Now I have to convert them back.
post #4 of 8 Old 07-22-2011, 03:24 PM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
You don't have to convert them for TMT5 you just need to mount them. Download Virtual CloneDrive and that will do the trick (at least this works for 2D ISO's).
William is offline
post #5 of 8 Old 07-22-2011, 08:43 PM
Joseph Clark's Avatar
Quoted: 266 Post(s)
Liked: 318
It works for 3D iso's, too, in both TMT5 and PowerDVD11. If your system is set to autoplay a disc, TMT5 or PDVD can start as soon as the iso is mounted - very simple.
Joe Clark
Joseph Clark is offline
post #6 of 8 Old 07-23-2011, 03:26 PM
TrickMcKaha's Avatar
Daemon Tools Light is also a free utility you can download and use to mount .iso disk images to play in PowerDVD and other software players. Once you install that utility, it will be clear how to actually mount the .iso as a drive.
TrickMcKaha is offline
post #7 of 8 Old 07-25-2011, 05:37 PM
mhetman's Avatar
Yup...works great with TMT 5 in either 2D or 3D.
ASUS Formula III Rampage MB
Intel I7 960 CPU ATI 5850
12GB RAM 58TB Storage
Windows 7 Ultra 64 Bit
Arcsoft TMT5, Ceton Infinity4
Denon x7200WA to Samsung HL67A750
mhetman is offline
post #8 of 8 Old 08-04-2011, 05:27 AM
BishopLord's Avatar
DVDFab Virtual Drive is what I used to use. It's a free. Once installed, you just right click on the .iso and "mount to (drive letter, usually H: )" and then when you open up TMT5, it'll be the drive or icon on the far right (of the 3 icons that would be displayed - BD player, HDD, Virtual Drive)
http://www.dvdfab.com/virtual-drive.htm
BishopLord is offline
Reply 3D Tech Talk
